Datasheet TPL9032 (3PEAK) - 7
Manufacturer3PEAK
Description300-mA High PSRR, Ultra-low Noise LDO
Pages / Page19 / 7 — TPL9032 Series. 300-mA High PSRR, Ultra-low Noise LDO. Pin Configuration …
TPL9032 Series. 300-mA High PSRR, Ultra-low Noise LDO. Pin Configuration and Functions. Pin Functions. PIN NUMBER. NAME. TYPE
TPL9032 Series 300-mA High PSRR, Ultra-low Noise LDO Pin Configuration and Functions Pin Functions PIN NUMBER NAME TYPE
TPL9032 Series 300-mA High PSRR, Ultra-low Noise LDO Pin Configuration and Functions TPL9032 Series
5-Pin SOT23 Package
TPL9032 Series
Top View 4-Pin DFN 1×1 Package Top View IN 1 5 OUT 4 3 IN EN Thermal GND 2 Pad OUT GND EN 3 4 NC 1 2
TPL9032 Series
4-Pin WLCSP Package Top View IN A1 A2 OUT EN B1 B2 GND
Pin Functions PIN NUMBER NAME TYPE DESCRIPTION SOT23-5 DFN-4 WLCSP-4
Regulator enable pin. Drive EN high to turn on the regulator; drive EN low to turn EN 3 3 B1 I off the regulator. For automatic startup, connect EN to IN directly. GND 2 2 B2 – Ground reference pin. Connect GND pin to PCB ground plane directly. IN 1 4 A1 I Input voltage pin. Bypass IN to GND with a 1 μF or greater capacitor. NC 4 – – – No connection. OUT 5 1 A2 O Regulated output voltage pin. Bypass OUT to GND with a 1 μF or greater capacitor. (1) Thermal Pad
MUST
be connected to PCB ground plane directly.
www.3peakic.com.cn Rev.A.1 7 / 19
