Datasheet MAX9000, MAX9001, MAX9002, MAX9003, MAX9004, MAX9005 (Analog Devices) - 8
Description | Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs |
Pages / Page | 20 / 8 — Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs |
File Format / Size | PDF / 255 Kb |
Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs _____________________________Typical Operating Characteristics (continued)
(VDD = +5V, VSS = 0, VCM (op amp) = 0, SHDN = VDD, COUT = low, RL = ∞, TA = +25°C, unless otherwise noted.)
MAX9000/MAX9001/MAX9002 MAX9000/MAX9001/MAX9002 OP-AMP TOTAL HARMONIC DISTORTION OP-AMP TOTAL HARMONIC DISTORTION MAX9000/MAX9001/MAX9002 PLUS NOISE vs. FREQUENCY PLUS NOISE vs. VAOUT OP-AMP OUTPUT IMPEDANCE vs. FREQUENCY
1 0.25 1k AV = +1 AV = +1 A V V = +1 IN = 2Vp-p VIN = 10kHz SINE WAVE NO LOAD 500 kHz LOWPASS FILTER 500kHz LOWPASS FILTER MAX9000 TOC28 0.20 MAX9000 TOC29 100 MAX9000 TOC30 R ) L TO VDD/2 RL TO VDD/2 Ω RL = 10kΩ 0.1 RL = 1kΩ 0.15 10 RL = 10kΩ 0.10 R 1 THD + NOISE (%) L = 1kΩ 0.01 THD + NOISE (%) R OUTPUT IMPEDANCE ( L = 100kΩ RL = 100kΩ 0.05 0.1 0.001 0 0.01
MAX9000–MAX9005
10 100 1k 10k 100k 4.0 4.1 4.2 4.3 4.4 4.5 4.6 4.7 4.8 4.9 5.0 100 1k 10k 100k 1M 10M FREQUENCY (Hz) VAOUT SWING (Vp-p) FREQUENCY (Hz)
MAX9003/MAX9004/MAX9005 MAX9003/MAX9004/MAX9005 OP-AMP TOTAL HARMONIC DISTORTION OP-AMP TOTAL HARMONIC DISTORTION MAX9003/MAX9004/MAX9005 PLUS NOISE vs. FREQUENCY PLUS NOISE vs. VAOUT OP-AMP OUTPUT IMPEDANCE vs. FREQUENCY
1 0.25 10k A AV = +10 V = +10 AV = +10 V VIN = 10kHz SINE WAVE IN = 200mVp-p NO LOAD 500kHz LOWPASS FILTER RL = 1kΩ 500kHz LOWPASS FILTER MAX9000 TOC31 0.20 MAX9000 TOC32 1k MAX9000 TOC33 ) R RL TO VDD/2 L TO VDD/2 Ω VIN VOUT R 0.15 100 L = 10kΩ RL 0.1 36k 4k 0.10 10 THD + NOISE (%) THD + NOISE (%) VIN VOUT RL = 100kΩ RL = 1kΩ OUTPUT IMPEDANCE ( RL 0.05 RL = 10kΩ 1 36k 4k RL = 100kΩ 0.01 0 0.1 10 100 1k 10k 100k 4.0 4.1 4.2 4.3 4.4 4.5 4.6 4.7 4.8 4.9 5.0 100 1k 10k 100k 1M 10M FREQUENCY (Hz) VAOUT SWING (Vp-p) FREQUENCY (Hz)
COMPARATOR COMMON-MODE CHANGE IN COMPARATOR OFFSET CHANGE IN COMPARATOR OFFSET REJECTION RATIO (CMRR) VOLTAGE (VOS) vs. SUPPLY VOLTAGE VOLTAGE (VOS) vs. TEMPERATURE vs. TEMPERATURE
200 200 95 150 150 MAX9000 TOC34 MAX9000 TOC35 93 MAX9000 TOC36 100 100 µV) µV) ( 50 ( 50 OS OS 91 0 0 CMRR (dB) -50 -50 89 CHANGE IN V CHANGE IN V -100 -100 87 -150 -150 -200 -200 85 2.5 3.0 3.5 4.0 4.5 5.0 5.5 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 SUPPLY VOLTAGE (V) TEMPERATURE (°C) TEMPERATURE (°C)
8 _______________________________________________________________________________________
