Datasheet 74LVC1G3157 (Nexperia) - 5
Manufacturer | Nexperia |
Description | 10 Ohm Single-Pole Double-Throw Analog Switch |
Pages / Page | 22 / 5 — Nexperia. 74LVC1G3157. 10 Ohm single-pole double-throw analog switch |
File Format / Size | PDF / 337 Kb |
link to page 5 link to page 5 link to page 5 link to page 5 link to page 6 link to page 5 link to page 5 link to page 5
Nexperia 74LVC1G3157 10 Ohm single-pole double-throw analog switch 10. Static characteristics Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground 0 V).
Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max
VIH HIGH-level input VCC = 1.65 V to 1.95 V 0.65 × VCC - - 0.65 × VCC - V voltage VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 3 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7 × VCC - - 0.7 × VCC - V VIL LOW-level input VCC = 1.65 V to 1.95 V - - 0.35 × VCC - 0.35 × VCC V voltage VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 3 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3 × VCC 0.3 × VCC V II input leakage pin S; VI = 5.5 V or GND; [2] - ±0.1 ±1 - ±1 μA current VCC = 0 V to 5.5 V IS(OFF) OFF-state leakage VCC = 5.5 V; see Fig. 3 [2] - ±0.1 ±0.2 - ±0.5 μA current IS(ON) ON-state VCC = 5.5 V; see Fig. 4 [2] - ±0.1 ±1 - ±2 μA leakage current ICC supply current VI = 5.5 V or GND; [2] - 0.1 4 - 4 μA VSW = GND or VCC; VCC = 1.65 V to 5.5 V ΔICC additional supply pin S; VI = VCC - 0.6 V; [2] - 5 500 - 500 μA current VCC = 5.5 V; VSW = GND or VCC CI input capacitance - 2.5 - - - pF CS(OFF) OFF-state - 6.0 - - - pF capacitance CS(ON) ON-state - 18 - - - pF capacitance [1] Typical values are measured at Tamb = 25 °C. [2] These typical values are measured at VCC = 3.3 V.
10.1. Test circuits
V switch S CC 1 VIH S Y0 1 2 VIL VIL or VIH switch IS Z Y1 2 VI VO GND 001aac358 VI = VCC or GND and VO = GND or VCC.
Fig. 3. Test circuit for measuring OFF-state leakage current
74LVC1G3157 All information provided in this document is subject to legal disclaimers. © Nexperia B.V. 2023. Al rights reserved
Product data sheet Rev. 10 — 13 April 2023 5 / 22
Document Outline 1. General description 2. Features and benefits 3. Ordering information 4. Marking 5. Functional diagram 6. Pinning information 6.1. Pinning 6.2. Pin description 7. Functional description 8. Limiting values 9. Recommended operating conditions 10. Static characteristics 10.1. Test circuits 10.2. ON resistance 10.3. ON resistance test circuit and graphs 11. Dynamic characteristics 11.1. Waveforms and test circuits 11.2. Additional dynamic characteristics 11.3. Test circuits 12. Package outline 13. Abbreviations 14. Revision history 15. Legal information Contents
