Datasheet 74LVC1G3157 (Nexperia) - 9
ManufacturerNexperia
Description10 Ohm Single-Pole Double-Throw Analog Switch
Pages / Page22 / 9 — Nexperia. 74LVC1G3157. 10 Ohm single-pole double-throw analog switch
File Format / SizePDF / 337 Kb
Nexperia 74LVC1G3157 10 Ohm single-pole double-throw analog switch
link to page 11 link to page 9 link to page 10 link to page 9 link to page 9 link to page 10 link to page 9 link to page 10 link to page 9 link to page 11 link to page 9
Nexperia 74LVC1G3157 10 Ohm single-pole double-throw analog switch 11. Dynamic characteristics Table 9. Dynamic characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 15.
Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max
tpd propagation Z to Yn or Yn to Z; see Fig. 12 [2] [3] delay VCC = 1.65 V to 1.95 V - - 2 - 3.0 ns VCC = 2.3 V to 2.7 V - - 1.2 - 2.0 ns VCC = 2.7 V - - 1.0 - 1.5 ns VCC = 3 V to 3.6 V - - 0.8 - 1.5 ns VCC = 4.5 V to 5.5 V - - 0.6 - 1.0 ns ten enable time S to Yn; see Fig. 13 [4] VCC = 1.65 V to 1.95 V 3.1 8.7 20.8 3.1 22.0 ns VCC = 2.3 V to 2.7 V 2.2 5.3 11.5 2.2 12.5 ns VCC = 2.7 V 2.1 4.9 9.3 2.1 10.2 ns VCC = 3 V to 3.6 V 1.8 4.0 7.6 1.8 9.0 ns VCC = 4.5 V to 5.5 V 1.5 3.0 5.7 1.5 6.1 ns tdis disable time S to Yn; see Fig. 13 [5] VCC = 1.65 V to 1.95 V 3.0 6.0 11.4 3.0 11.7 ns VCC = 2.3 V to 2.7 V 2.1 4.4 7.3 2.1 7.6 ns VCC = 2.7 V 2.1 4.2 6.3 2.1 6.6 ns VCC = 3 V to 3.6 V 1.7 3.6 5.3 1.7 5.9 ns VCC = 4.5 V to 5.5 V 1.3 2.9 3.8 1.3 4.3 ns tb-m break-before- see Fig. 14 [6] make time VCC = 1.65 V to 1.95 V 0.5 - - 0.5 - ns VCC = 2.3 V to 2.7 V 0.5 - - 0.5 - ns VCC = 2.7 V 0.5 - - 0.5 - ns VCC = 3 V to 3.6 V 0.5 - - 0.5 - ns VCC = 4.5 V to 5.5 V 0.5 - - 0.5 - ns [1] Typical values are measured at Tamb = 25 °C and nominal VCC. [2] tpd is the same as tPLH and tPHL. [3] Propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified capacitance when driven by an ideal voltage source (zero output impedance). [4] ten is the same as tPZH and tPZL. [5] tdis is the same as tPLZ and tPHZ. [6] Break-before-make specified by design. 74LVC1G3157 All information provided in this document is subject to legal disclaimers. © Nexperia B.V. 2023. Al rights reserved
Product data sheet Rev. 10 — 13 April 2023 9 / 22
Document Outline 1. General description 2. Features and benefits 3. Ordering information 4. Marking 5. Functional diagram 6. Pinning information 6.1. Pinning 6.2. Pin description 7. Functional description 8. Limiting values 9. Recommended operating conditions 10. Static characteristics 10.1. Test circuits 10.2. ON resistance 10.3. ON resistance test circuit and graphs 11. Dynamic characteristics 11.1. Waveforms and test circuits 11.2. Additional dynamic characteristics 11.3. Test circuits 12. Package outline 13. Abbreviations 14. Revision history 15. Legal information Contents
