Datasheet LM194, LM394 (National Semiconductor) - 5
ManufacturerNational Semiconductor
DescriptionSupermatch Pair
Pages / Page10 / 5 — Typical. Applications. (Continued). High. Performance. Instrumentation. …
File Format / SizePDF / 238 Kb
Typical. Applications. (Continued). High. Performance. Instrumentation. Amplifier. 106. *Gain. e. RS. TL/H/9241. –. 7. Performance. Characteristics. G. e
Typical Applications (Continued) High Performance Instrumentation Amplifier 106 *Gain e RS TL/H/9241 – 7 Performance Characteristics G e
Typical Applications (Continued) High Performance Instrumentation Amplifier 106 *Gain e RS TL/H/9241 – 7 Performance Characteristics G e 10,000 G e 1,000 G e 100 G e 10 Linearity of Gain (g10V Output) s0.01 s0.01 s0.02 s0.05 % Common-Mode Rejection Ratio (60 Hz) t120 t120 t110 t90 dB Common-Mode Rejection Ratio (1 kHz) t110 t110 t90 t70 dB Power Supply Rejection Ratio a Supply l110 l110 l110 l110 dB bSupply l110 l110 l90 l70 dB Bandwidth (b3 dB) 50 50 50 50 kHz Slew Rate 0.3 0.3 0.3 0.3 V/ms Offset Voltage Drift** s0.25 s0.4 2 s10 mV/§C Common-Mode Input Resistance l109 l109 l109 l109 X Differential Input Resistance l3 x 108 l3 x 108 l3 x 108 l3 x 108 X nV Input Referred Noise (100 Hz s f s 10 kHz) 5 6 12 70 0Hz Input Bias Current 75 75 75 75 nA Input Offset Current 1.5 1.5 1.5 1.5 nA Common-Mode Range g 11 g 11 g 11 g 10 V Output Swing (RL e 10 kX) g 13 g 13 g 13 g 13 V **Assumes s 5 ppm/§C tracking of resistors 5
