Datasheet 17DCT Athlonix (Portescap)
Manufacturer | Portescap |
Description | Brush DC Motors |
Pages / Page | 2 / 1 — Brush DC Motors 17DCT Athlonix™. 17DCT 26P2 •••• .2. 17DCT 26P1 •••• .1. … |
File Format / Size | PDF / 440 Kb |
Brush DC Motors 17DCT Athlonix™. 17DCT 26P2 •••• .2. 17DCT 26P1 •••• .1. Electrical Data. Symbol. 17DCT 26P1/P2 •••• .*. Unit. 216P
Ø 17 mm • Precious metal commutation • 6.14 mNm (Ø9±0.05) 0 -0.1 0 -0.1 0 -0.1 0 -0.1 -0.006 -0.009 17 17 (2.1) Ø 16 16 (6x60 1.5 Ø Ø Ø -0.022 -0.006 -0.009 0 Ø 6 -0.022 -0.006 -0.009 4.5 0 6 4.5 °) Ø 1.5 Ø Ø 1.5 Ø Ø Ø (9) (8.2) 6.35±0.5 6.35±0.5 2.5±0.4 (1.5) (1) (6.5) (1.5) (1) (6x M1.6 x 2.5 deep) 6.8±0.5 25.5±0.5 7.5±0.5 6.8±0.5 25.5±0.5 7.5±0.5
17DCT 26P2 •••• .2 17DCT 26P1 •••• .1
Dimensions in mm.
Electrical Data Symbol 17DCT 26P1/P2 •••• .* Unit 216P 211P 209P 208P 207P
1 Nominal Voltage V 3 6 9 12 15 Volt 2 No-Load Speed n0 7838 7842 7645 8158 8358 rpm 3 No-Load Current I0 24.7 12.3 8.0 6.4 5.3 mA 4 Terminal Resistance R 0.9 3.3 7.7 12.1 18.6 Ω 5 Output Power P2max. 4.6 4.7 4.8 4.7 4.7 W 6 Stall Torque mNm 12.31 (1.75) 13.21 (1.88) 13.02 (1.85) 13.79 (1.96) 13.62 (1.93) mNm (oz-in) 7 Efficiency hmax. 84 84 84 85 84 % 8 Max Continuous Speed ne max. 10000 10000 10000 10000 10000 rpm 9 Max Continuous Torque Me max. 5.81 (0.83) 6.02 (0.86) 6.05 (0.86) 6.03 (0.86) 5.92 (0.84) mNm (oz-in) 10 Max Continuous Current Ie max. 1.63 0.84 0.55 0.44 0.35 A 11 Back-EMF Constant kE 0.38 0.76 1.17 1.46 1.78 mV/rpm 12 Torque Constant kM 3.63 7.26 11.16 13.96 17.03 mNm/A 13 Motor Regulation R/k2 66.64 62.15 61.45 61.92 64.25 103/Nms 14 Friction Torque TF 0.08 (0.011) 0.08 (0.011) 0.08 (0.011) 0.08 (0.011) 0.08 (0.011) mNm (oz-in) 15 Mechanical Time Constant τm 7.01 6.41 6.30 6.27 6.25 ms 16 Rotor Inertia J 1.05 1.03 1.02 1.01 0.97 g-cm2
General Data
17 Thermal Resistance (rotor/body) R / th1 Rth2 6/25 °C/W 18 Thermal Time Constant (rotor/stator) tW1/tW2 12/250 S 19 Operating Temperature Range: motor -30°C to 85°C (-22°F to 185°F) °C (°F) rotor 100°C (212°F) °C (°F) 20 Shaft Load Max.: With sleeve bearings (5 mm. from bearing) -radial 1.5 (5.39) N (oz) -axial 100 (359.6) N (oz) 21 Shaft Play: -radial 0.03 (0.0012) mm (inch) -axial 0.15 (0.0059) mm (inch) 22 Weight g 27 (0.96) g (oz) 23 Commutation Segment - 9 segment *Also available with ball bearing
Execution Table No Load Speed vs. Torque
10000
Gearbox Single Shaft MR2 M Sense B
Max. Recommended Speed R16 1 2 10 8000 Max. Continuous Output B16 3 4 11
Power 4.7W 6000 BA16 3 4 11
n (rpm
4000 Note: P1: standard commutation 2000 P2: special commutation for double shaft version 0 0 6.03 12.06 18.09 24.12 Motor shaft rotates CW when seen from motor front face
M (mNm)
when +ve and -ve supply is given to respective terminals. Continuous working range Temporary working range V012021
© 2021 Portescap. Specifications subject to change without notice.
85
