Datasheet J104D (CIT Relay & Switch)
ManufacturerCIT Relay & Switch
DescriptionUL Approved Relay
Pages / Page2 / 1 — J104D. Features. Contact Data*. Coil Data*. General Data*
File Format / SizePDF / 320 Kb
Datasheet J104D CIT Relay & Switch
J104D
20.4 x 10.1 x 11.0 mm
Features
• High sensitivity E197851 • Low cost • Conforms to FCC part 68 • Clearance more than 1.2mm between coil and contacts • Creepage more than 1.9mm between coil and contacts • Bifurcated contacts for high reliability
Contact Data*
Contact Arrangement 2C = DPDT Bifurcated Contacts Maximum Switching Power 48W, 120VA Contact Rating 2A @ 24VDC, Resistive Maximum Switching Voltage 250VAC, 100VDC 1A @ 120VAC, Resistive Maximum Switching Current 2A Contact Material AgNi + Au Clad Contact Resistance ≤ 50 milliohms initial
Coil Data*
Coil Voltage Coil Resistance Pick Up Voltage Release Voltage Coil Power Operate Time Release Time VDC Ω +/- 10% VDC (max) VDC (min) W ms ms 75% of rated 10% of rated Rated Max .15W .20W .36W .45W voltage voltage 3 3.9 60 45 25 20 2.25 0.3 5 6.5 167 125 70 56 3.75 0.5 6 7.8 240 180 100 80 4.50 0.6 .15 .20 9 11.7 540 405 225 180 6.75 0.9 6 4 .36 12 15.6 960 720 400 320 9.00 1.2 .45 24 31.2 3840 2880 1600 1280 18.00 2.4 48 62.4 n/a 11520 6400 5100 36.00 4.8
General Data*
Electrical Life @ rated load 100K cycles, average * Values can change due to the switching frequency, desired reliability levels, environmental conditions and in-rush load levels. Mechanical Life 10M cycles, average It is recommended to test actual load conditions for the applica- tion. It is the user’s responsibility to determine the performance Insulation Resistance 100M Ω min. @ 500VDC initial suitability for their specifi c application. The use of any coil voltage Dielectric Strength, Coil to Contact 1000V rms min. @ sea level initial less than the rated coil voltage may compromise the operation of the relay. Contact to Contact 500V rms min. @ sea level initial Shock Resistance 100m/s2 for 11 ms Vibration Resistance 1.5mm double amplitude 10~40Hz Terminal (Copper Alloy) Strength 5N Operating Temperature -40oC to +85oC Storage Temperature -40oC to +85oC Solderability 260oC for 5 s Weight 5g Dimensions are shown for reference purposes only. 1 of 2 www.CITRelay.com Specifi cations and availability subject to change without notice. sales@CITRelay.com J104D Rev B 10/2022
