H11F1M, H11F2M, H11F3MELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise noted) INDIVIDUAL COMPONENT CHARACTERISTICSSymbolParameterTest ConditionsMinTyp*MaxUnitEMITTER VF Input Forward Voltage IF = 16 mA − 1.3 1.75 V IR Reverse Leakage Current VR = 5 V − − 10 mA CJ Capacitance V = 0 V, f = 1.0 MHz − 50 − pF OUTPUT DETECTOR BV4−6 Breakdown Voltage H11F1M, I4−6 = 10 mA, IF = 0 30 − − V Either Polarity H11F2M H11F3M 15 − − I4−6 Off−State Dark Current V4−6 = 15 V, IF = 0 − − 50 nA V4−6 = 15 V, IF = 0, − − 50 mA TA = 100°C R4−6 Off−State Resistance V4−6 = 15 V, IF = 0 300 − − MW C4−6 Capacitance V4−6 = 15 V, IF = 0, − − 15 pF f = 1 MHz TRANSFER CHARACTERISTICSSymbolCharacteristicsTest ConditionsMinTyp*MaxUnitDC CHARACTERISTICS R4−6 On−State Resistance H11F1M IF = 16 mA, I4−6 = 100 mA − − 200 W H11F2M − − 330 H11F3M − − 470 R6−4 On−State Resistance H11F1M IF = 16 mA, I6−4 = 100 mA − − 200 W H11F2M − − 330 H11F3M − − 470 Resistance, Non−Linearity and Assymetry IF = 16 mA, I4−6 = 25 mA RMS, − 2 − % f = 1 kHz AC CHARACTERISTICS ton Turn−On Time RL = 50 W, IF = 16 mA, − − 45 ms V4−6 = 5 V toff Turn−Off Time RL = 50 W, IF = 16 mA, − − 45 ms V4−6 = 5 V ISOLATION CHARACTERISTICSSymbolCharacteristicsTest ConditionsMinTyp*MaxUnit VISO Input−Output Isolation Voltage t = 1 Minute 4170 − − VACRMS RISO Isolation Resistance VI−O = 500 VDC 1011 − − W CISO Isolation Capacitance f = 1 MHz − 0.2 − pF Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. *All Typical values at TA= 25°C. www.onsemi.com3
