Datasheet MBT3906DW1 (ON Semiconductor) - 8
ManufacturerON Semiconductor
DescriptionDual General Purpose Transistor
Pages / Page9 / 8 — SC−88/SC70−6/SOT−363. DOCUMENT NUMBER: 98ASB42985B. DESCRIPTION:. PAGE 2 …
File Format / SizePDF / 354 Kb
SC−88/SC70−6/SOT−363. DOCUMENT NUMBER: 98ASB42985B. DESCRIPTION:. PAGE 2 OF 2. onsemi
SC−88/SC70−6/SOT−363 DOCUMENT NUMBER: 98ASB42985B DESCRIPTION: PAGE 2 OF 2 onsemi
CASE 419B−02 ISSUE Y DATE 11 DEC 2012 STYLE 1: STYLE 2: STYLE 3: STYLE 4: STYLE 5: STYLE 6: PIN 1. EMITTER 2 CANCELLED CANCELLED PIN 1. CATHODE PIN 1. ANODE PIN 1. ANODE 2 2. BASE 2 2. CATHODE 2. ANODE 2. N/C 3. COLLECTOR 1 3. COLLECTOR 3. COLLECTOR 3. CATHODE 1 4. EMITTER 1 4. EMITTER 4. EMITTER 4. ANODE 1 5. BASE 1 5. BASE 5. BASE 5. N/C 6. COLLECTOR 2 6. ANODE 6. CATHODE 6. CATHODE 2 STYLE 7: STYLE 8: STYLE 9: STYLE 10: STYLE 11: STYLE 12: PIN 1. SOURCE 2 CANCELLED PIN 1. EMITTER 2 PIN 1. SOURCE 2 PIN 1. CATHODE 2 PIN 1. ANODE 2 2. DRAIN 2 2. EMITTER 1 2. SOURCE 1 2. CATHODE 2 2. ANODE 2 3. GATE 1 3. COLLECTOR 1 3. GATE 1 3. ANODE 1 3. CATHODE 1 4. SOURCE 1 4. BASE 1 4. DRAIN 1 4. CATHODE 1 4. ANODE 1 5. DRAIN 1 5. BASE 2 5. DRAIN 2 5. CATHODE 1 5. ANODE 1 6. GATE 2 6. COLLECTOR 2 6. GATE 2 6. ANODE 2 6. CATHODE 2 STYLE 13: STYLE 14: STYLE 15: STYLE 16: STYLE 17: STYLE 18: PIN 1. ANODE PIN 1. VREF PIN 1. ANODE 1 PIN 1. BASE 1 PIN 1. BASE 1 PIN 1. VIN1 2. N/C 2. GND 2. ANODE 2 2. EMITTER 2 2. EMITTER 1 2. VCC 3. COLLECTOR 3. GND 3. ANODE 3 3. COLLECTOR 2 3. COLLECTOR 2 3. VOUT2 4. EMITTER 4. IOUT 4. CATHODE 3 4. BASE 2 4. BASE 2 4. VIN2 5. BASE 5. VEN 5. CATHODE 2 5. EMITTER 1 5. EMITTER 2 5. GND 6. CATHODE 6. VCC 6. CATHODE 1 6. COLLECTOR 1 6. COLLECTOR 1 6. VOUT1 STYLE 19: STYLE 20: STYLE 21: STYLE 22: STYLE 23: STYLE 24: PIN 1. I OUT PIN 1. COLLECTOR PIN 1. ANODE 1 PIN 1. D1 (i) PIN 1. Vn PIN 1. CATHODE 2. GND 2. COLLECTOR 2. N/C 2. GND 2. CH1 2. ANODE 3. GND 3. BASE 3. ANODE 2 3. D2 (i) 3. Vp 3. CATHODE 4. V CC 4. EMITTER 4. CATHODE 2 4. D2 (c) 4. N/C 4. CATHODE 5. V EN 5. COLLECTOR 5. N/C 5. VBUS 5. CH2 5. CATHODE 6. V REF 6. COLLECTOR 6. CATHODE 1 6. D1 (c) 6. N/C 6. CATHODE STYLE 25: STYLE 26: STYLE 27: STYLE 28: STYLE 29: STYLE 30: PIN 1. BASE 1 PIN 1. SOURCE 1 PIN 1. BASE 2 PIN 1. DRAIN PIN 1. ANODE PIN 1. SOURCE 1 2. CATHODE 2. GATE 1 2. BASE 1 2. DRAIN 2. ANODE 2. DRAIN 2 3. COLLECTOR 2 3. DRAIN 2 3. COLLECTOR 1 3. GATE 3. COLLECTOR 3. DRAIN 2 4. BASE 2 4. SOURCE 2 4. EMITTER 1 4. SOURCE 4. EMITTER 4. SOURCE 2 5. EMITTER 5. GATE 2 5. EMITTER 2 5. DRAIN 5. BASE/ANODE 5. GATE 1 6. COLLECTOR 1 6. DRAIN 1 6. COLLECTOR 2 6. DRAIN 6. CATHODE 6. DRAIN 1 Note: Please refer to datasheet for style callout. If style type is not called out in the datasheet refer to the device datasheet pinout or pin assignment.
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red.
DESCRIPTION: SC−88/SC70−6/SOT−363 PAGE 2 OF 2 onsemi
and are trademarks of Semiconductor Components Industries, LLC dba
onsemi
or its subsidiaries in the United States and/or other countries.
onsemi
reserves the right to make changes without further notice to any products herein.
onsemi
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does
onsemi
assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages.
onsemi
does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2019 www.onsemi.com
