Datasheet S6428-01, S6429-01, S6430-01, S7505-01 (Hamamatsu)
ManufacturerHamamatsu
DescriptionSi Photodiodes
Pages / Page6 / 1 — Si photodiodes. S6428-01 S6429-01 S6430-01 S7505-01 RGB color sensor
File Format / SizePDF / 232 Kb
Datasheet S6428-01, S6429-01, S6430-01, S7505-01 Hamamatsu
Si photodiodes
The S6428-01, S6429-01 and S6430-01 are color sensors designed to respectively detect monochromatic colors of blue
(λp=460 nm), green (λp=540 nm) and red (λp=660 nm).
The S7505-01 uses a 3-channel (RGB) photodiode having blue, green and red sensitivities, and is molded into a surface
mount type package. Features Applications
White balance adjustment S6428-01, S6429-01, S6430-01 Color identification Plastic package (6 × 8 mm) Projector and TV brightness level detection Spectral response range
S6428-01: 400 to 540 nm (λp=460 nm)
S6429-01: 480 to 600 nm (λp=540 nm)
S6430-01: 590 to 720 nm (λp=660 nm) Color control
Light source color temperature detection Insensitive to near IR range
High sensitivity
S6428-01: 0.22 A/W Typ. (λ=λp)
S6429-01: 0.27 A/W Typ. (λ=λp)
S6430-01: 0.45 A/W Typ. (λ=λp)
Low dark current S7505-01
3 ch (RGB) Si photodiode
Surface mount type plastic package (9 × 9.6 mm)
High sensitivity Structure / Absolute maximum ratings Type no. S6428-01
S6429-01
S6430-01
S7505-01 Photosensitive area
size Effective
photosensitive
area (mm) (mm2) 2.4 × 2.8 6.7 Reverse
voltage
VR max
(V) 10 Absolute maximum ratings
Operating
Storage
temperature
temperature
Topr
Tstg
(°C)
(°C) -10 to +60 -20 to +70 Green, Red: 1.5 × 1.5
Green, Red: 2.25
Blue
: 1.5 × 1.5 (2 elements) Blue
: 4.5 Note: Exceeding the absolute maximum ratings even momentarily may cause a drop in product quality. Always be sure to use the
product within the absolute maximum ratings. www.hamamatsu.com 1
