Datasheet SB120, SB130, SB140, SB150, SB160 (PanJit)
ManufacturerPanJit
DescriptionSchottky Barrier Rectifiers
Pages / Page4 / 1 — SB120~SB160. SCHOTTKY BARRIER RECTIFIERS. VOLTAGE 20 to 60 Volt CURRENT …
File Format / SizePDF / 212 Kb
SB120~SB160. SCHOTTKY BARRIER RECTIFIERS. VOLTAGE 20 to 60 Volt CURRENT 1.0 Ampere FEATURES
Datasheet SB120, SB130, SB140, SB150, SB160 PanJit
SB120~SB160
• Plastic package has Underwriters Laboratory
Flammability Classification 94V-O utilizing
Flame Retardant Epoxy Molding Compound. 0.034(0.86)
0.028(0.71) • For use in low voltage,high frequency inverters ,free wheeling ,
and polarity protection applications . 0.205 (5.2 )
0.160 (4.1 ) • Lead free in compliance with EU RoHS 2.0 MECHANICALDATA
• Case: DO-41 Molded plastic
• Terminals: Axial leads, solderable per MIL-STD-750,Method 2026
• Polarity: Color band denotes cathode 0.107(2.7)
0.080(2.0) 1.0(2 5.4 )MIN. • Weight: 0.0118 ounces, 0.336 grams MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. PARAMETER SYMBOL SB120 SB130 SB140 SB150 SB160 UNITS Maximum Recurrent Peak Reverse Voltage V RRM 20 30 40 50 60 V Maximum RMS Voltage VRMS 14 21 28 35 42 V Maximum DC Blocking Voltage VDC 20 30 40 50 60 V Maximum Average Forward Rectified Current 0.375"(9.5mm)
lead length (See Figure1) IF(AV) 1.0 A Peak Forward Surge Current : 8.3ms single half sine-wave
superimposed on rated load IFSM 30 A Maximum Forward Voltage at 1.0A VF 0.5 0.7 V IR 0.2
10 0.1
10 mA Maximum DC Reverse Current at Rated DC Blocking Voltage Typical Thermal Resistance
Operating Junction and Storage Temperature Range June 14,2017­REV.04 TJ=25OC
TJ=100OC RθJA
TJ,TSTG O 50
-55 to +125 C/W -55 to +150 O C PAGE . 1
