Datasheet HCPL-7800A, HCPL-7800 (Broadcom) - 9
ManufacturerBroadcom
DescriptionIsolation Amplifier
Pages / Page20 / 9 — HCPL-7800A/HCPL-7800. Package Characteristics. Parameter. Symbol. Min. …
File Format / SizePDF / 829 Kb
HCPL-7800A/HCPL-7800. Package Characteristics. Parameter. Symbol. Min. Typ. Max. Units. Test Condition. Fig. Note
HCPL-7800A/HCPL-7800 Package Characteristics Parameter Symbol Min Typ Max Units Test Condition Fig Note
link to page 9
Data Sheet Isolation Amplifer
Package Characteristics Parameter Symbol Min. Typ. Max. Units Test Condition Fig. Note
Input-Output Momentary VISO 3750 — — Vrms RH < 50%, t = 1 minute, a, b Withstand Voltage TA = 25°C Resistance (Input-Output) RI-O — >109 — Ω VI-O = 500 VDC c Capacitance (Input-Output) CI-O — 1.2 — p F ƒ = 1 MHz c a. In accordance with UL 1577, each optocoupler is proof tested by applying an insulation test voltage ≥ 4500 Vrms for 1 second (leakage detection current limit, II-O ≤ 5 µA). This test is performed before the 100% production test for partial discharge (method b) shown in IEC/EN/DIN EN 60747-5-5 Insulation Characteristics Table. b. The Input-Output Momentary Withstand Voltage is a dielectric voltage rating that should not be interpreted as an input-output continuous voltage rating. For the continuous voltage rating, refer to the IEC/EN/DIN EN 60747-5-5 Insulation Characteristics Table and your equipment level safety specification. c. This is a two-terminal measurement: pins 1–4 are shorted together and pins 5–8 are shorted together.
Figure 2: Input Offset Voltage Test Circuit VDD1 VDD2 +15 V 0.1 μF 1 8 0.1 μF 2 7 10 kΩ + HCPL-7800 VOUT 0.1 μF 3 6 10 kΩ - AD624CD GAIN = 100 4 5 0.1 μF 0.47 0.47 μF μF -15 V Figure 3: Input Offset Voltage vs. Temperature Figure 4: Input Offset vs. Supply 0.8 0.39 vs. VDD1 0.7 0.38 vs. VDD2 0.6 0.37 0.5 0.36 0.4 0.35 - INPUT OFFSET VOLTAGE - mV - INPUT OFFSET VOLTAGE - mV V OS 0.3 V OS 0.34 0.2 0.33 -55 -25 5 35 65 95 125 4.5 4.75 5.0 5.25 5.5 TA - TEMPERATURE - °C VDD - SUPPLY VOLTAGE - V
Broadcom AV02-0410EN 9 Document Outline Description Features Applications Functional Diagram Ordering Information Package Outline Drawings Standard DIP Package Gull Wing Surface Mount Option 300 Solder Reflow Profile Regulatory Information IEC/EN/DIN EN 60747-5-5 Insulation Characteristics Insulation and Safety-Related Specifications Absolute Maximum Ratings Recommended Operating Conditions DC Electrical Specifications AC Electrical Specifications Package Characteristics Application Information Power Supplies and Bypassing PC Board Layout Current Sensing Resistors Sense Resistor Connections Output Side Frequently Asked Questions about the HCPL-7800(A) Basics Sense Resistor and Input Filter Isolation and Insulation Accuracy Power Supplies and Start-Up Miscellaneous
