Datasheet EDR1, EDR2, EDR3 (ECE) - 3
ManufacturerECE
DescriptionReed Relay
Pages / Page8 / 3 — Rely on ECE’s Relays,. and You Always Relax!. PART NUMBER SYSTEM
File Format / SizePDF / 300 Kb
Rely on ECE’s Relays, and You Always Relax! PART NUMBER SYSTEM
PART NUMBER SYSTEM
EDR 1 0 1A 05 00 Z Z: RoHS Compliant Special code: 00~99 00: Pin out 1357 50: Pin out 1267 Nominal voltage: 05: 5 VDC, 12: 12VDC, 24: 24VDC Contact form: 1A: Open type, 1 form A Function: 0: Normal function D: With diode type M: With magnetic shield type N: With diode and magnetic shield type Type: 1: SIP type Series name EDR 2 0 1A 05 00 Z Z: RoHS Compliant Special code: 00~99 00: Standard (Pin2 and Pin13 are connected) 50: Pin2 and Pin13 are disconnected Nominal voltage: 05: 5VDC, 12: 12VDC, 24: 24VDC Contact Form: 1A: Open type, 1 form A 2A: Open type, 2 form A 1B: Close type, 1 form B 1C: 1 open 1 close type, 1 form C Function: 0: Normal function D: With diode type H: High insulation (Apply to 1A &1B) K: High insulation with diode type (Apply to 1A &1B) M: Normal function with magnetic shield N: Diode type with magnetic shield E: With electrostatic shield ( Apply to 1A &2A ) F: With electrostatic shield and diode type(Apply to 1A&2A) Type: 2: DIP type 3: SMD type Series name 3 For the latest product information, Please visit our website at http://www.ece.com.tw
