Datasheet X100-7 THD (First Sensor)
ManufacturerFirst Sensor
DescriptionFirst Sensor PIN PD
Pages / Page3 / 1 — www.first-sensor.com
File Format / SizePDF / 750 Kb
Datasheet X100-7 THD First Sensor
First Sensor PIN PD Data Sheet Part Description X100-7 THD Order # 3001447; 3001448 Features Description Application RoHS • 100 mm² PIN detector Square active area PIN photodiode • Ionizing radiation detector 2011/65/EU • CsI:Tl scintillator with 100 mm² active area. Ceramic • Medical equipment • Low dark current • Personal dosimeter carrier type 2-pin package with CsI:Tl • Low capacitance scintillator (8 mm #3001447; 4 mm • High shunt resistance #3001448). • High sensitivity Absolute maximum ratings Absorption of gamma radiation (23 °C) Symbol Parameter Min Max Unit 100,0% TSTG Storage temp -40 65 °C T ) OP Operating temp -20 60 °C %( V max Max reverse voltage 50 V ityil I b PEAK Peak DC current 10 mA a b o 10,0% r p Schematic n tio p #5000040: 380µm Si r Pin 2 so b #3001448: 4 mm CsI:Tl A #3001447: 8 mm CsI:Tl 1,0% 10 100 1000 10000 Pin 1 Gamma energy (keV) Electro-optical characteristics @ 23 °C Symbol Characteristic Test Condition Min Typ Max Unit Active area 10 x 10 mm Active area 100 mm² Detectable radiation Gamma radiation 1 10000 keV Scintillator thickness # 3001448; Material: CsI:Tl 4 mm # 3001447; Material: CsI:Tl 8 mm Count rate Cs-137 # 3001448; V 750 cpm / R = 10 V 500 # 3001447; VR = 10 V 800 1200 µSv/h ID Dark current VR = 10 V 1.5 2.5 nA Sabs Responsivity VR = 10 V; λ = 550 nm (emission peak of CsI:Tl) 0.27 A/W C Capacitance VR = 0 V; f = 10 kHz 500 pF VR = 10 V; f = 10 kHz 80 105 pF tR Rise time VR = 10 V; E = 622 keV; RL = 50 Ω 1 µs Shunt Resistance VR = 10 mV 40 MΩ Noise current VR = 10V 6.1 E-14 A/√Hz VBR Breakdown voltage IR = 2 µA 50 80 V Rev. 08/03/2018 subject to change without notice
contact@first-sensor.com Page 1/3
