Datasheet LMX331, LMX393, LMX339 (Maxim) - 4
ManufacturerMaxim
DescriptionGeneral-Purpose, Low-Voltage, Single/Dual/Quad, Tiny-Pack Comparators
Pages / Page9 / 4 — General-Purpose, Low-Voltage, Single/Dual/Quad, Tiny-Pack Comparators. DC …
File Format / SizePDF / 190 Kb
General-Purpose, Low-Voltage, Single/Dual/Quad, Tiny-Pack Comparators. DC ELECTRICAL CHARACTERISTICS—1.8V OPERATION
General-Purpose, Low-Voltage, Single/Dual/Quad, Tiny-Pack Comparators DC ELECTRICAL CHARACTERISTICS—1.8V OPERATION
(VDD = 1.8V, VSS = 0V, VCM = 0V, RL = 5.1kΩ connected to VDD. Typical values are at TA = +25°C.
Boldface
limits apply at the defined temperature extremes.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
Input Offset Voltage VOS 0.2 5 mV Input Voltage Hysteresis LMX331H/LMX393H/LMX339H only 2 mV Input Offset Voltage Average TCVOS 5 µV/°C Temperature Drift Input Bias Current IB 0.05 nA Input Offset Current IOS 0.05 nA -0.1 Input Voltage Range VCM V 1 Output Saturation Voltage VSAT ISINK ≤ 1mA 35 mV Power-Supply Rejection Ratio PSRR VDD = 1.8V to 5.5V 60 70 dB Output Sink Current IO VO ≤ 1.5V 15 mA LMX331/LMX331H 40 100 Supply Current (Note 2) IS LMX393/LMX393H (both comparators) 65 140 µA LMX339/LMX339H (all four comparators) 120 200 Output Leakage Current 0.003 µA
LMX331/LMX393/LMX339 AC ELECTRICAL CHARACTERISTICS—1.8V OPERATION
Boldface
Propagation Delay Input overdrive = 10mV (Note 3) 500 tPHL ns Output High to Low Input overdrive = 100mV (Note 3) 100 Propagation Delay Input overdrive = 10mV (Note 3) 500 tPLH ns Output Low to High Input overdrive = 100mV (Note 3) 100
Note 1:
All devices are production tested at +25°C. All temperature limits are guaranteed by design.
Note 2:
Supply current when output is high.
Note 3:
Input overdrive is the overdrive voltage beyond the offset and hysteresis-determined trip points.
4 _______________________________________________________________________________________
