Datasheet SFH6156 (Vishay) - 5
ManufacturerVishay
DescriptionOptocoupler, Phototransistor Output, High Reliability, 5300 V RMS
Pages / Page9 / 5 — SFH6156. SAFETY AND INSULATION RATINGS PARAMETER. TEST CONDITION. SYMBOL. …
File Format / SizePDF / 174 Kb
SFH6156. SAFETY AND INSULATION RATINGS PARAMETER. TEST CONDITION. SYMBOL. VALUE. UNIT. Note. TYPICAL CHARACTERISTICS
SFH6156 SAFETY AND INSULATION RATINGS PARAMETER TEST CONDITION SYMBOL VALUE UNIT Note TYPICAL CHARACTERISTICS
SFH6156
Climatic classification According to IEC 68 part 1 55/100/21 Comparative tracking index CTI 175 Maximum rated withstanding isolation voltage t = 1 min VISO 4420 VRMS Maximum transient isolation voltage VIOTM 10 000 V Maximum repetitive peak isolation voltage VIORM 890 V VIO = 500 V, Tamb = 25 °C RIO ≥ 1012 Ω Isolation resistance VIO = 500 V, Tamb = 100 °C RIO ≥ 1011 Ω Output safety power PSO 400 mW Input safety current ISI 275 mA Input safety temperature TSI 175 °C Creepage distance ≥ 7 mm Clearance distance ≥ 7 mm Insulation thickness DTI ≥ 0.4 mm
Note
• As per IEC 60747-5-5, § 7.4.3.8.2, this optocoupler is suitable for “safe electrical insulation” only within the safety ratings. Compliance with the safety ratings shall be ensured by means of protective circuits
(Tamb = 25 °C, unless otherwise specified) 103 I = 10 mA, V = 5 V F CE I R = 75 5 F Ω L 4 V = 5 V CC 3 IC (%) 2 I C I 102 1 5 47 Ω isfh615a_01 101 - 25 0 25 50 75 isfh615a_03 T (°C) A Fig. 2 - Linear Operation (without saturation) Fig. 4 - Current Transfer Ratio (typ.) vs. Temperature 30 I =14 mA F I 1 F Ω 12 mA V = 5 V CC 20 10 mA (mA) 8 mA I C 10 6 mA 47 Ω 4 mA 1 mA 2 mA isfh615a_02 0 0 5 10 15 isfh615a_04 V (V) CE Fig. 3 - Switching Operation (with saturation) Fig. 5 - Output Characteristics (typ.) Collector Current vs. Collector Emitter Voltage Rev. 3.0, 15-Mar-2023
5
Document Number: 83671 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
