Datasheet MPM (Vishay) - 3
ManufacturerVishay
DescriptionMolded, SOT-23 Thin Film Resistor, Surface Mount Divider Network
Pages / Page4 / 3 — MPM (Divider). GLOBAL PART NUMBER INFORMATION New Global Part Numbering: …
File Format / SizePDF / 108 Kb
MPM (Divider). GLOBAL PART NUMBER INFORMATION New Global Part Numbering: MPM1003AWS. MPM. MPMT
MPM (Divider) GLOBAL PART NUMBER INFORMATION New Global Part Numbering: MPM1003AWS MPM MPMT
MPM (Divider)
www.vishay.com Vishay Dale Thin Film
GLOBAL PART NUMBER INFORMATION New Global Part Numbering: MPM1003AWS M P M 1 0 0 3 A W S M P M T 1 0 0 1 5 0 0 1 A T 1
GLOBAL MODEL RESISTANCE TOLERANCE AND (3 or 4 digits) (4 or 8 digits) RATIO TOLERANCE (1) PACKAGING
MPM
First 3 digits are significant Abs. Tol. Ratio
BS
= BULK 100 min., 1 mult. (Tin lead) figures and the last digit
WS
= WAFFLE 100 min., 1 mult. specifies the number of zeros
A
= 0.1 % 0.05 %
MPMT
to follow. When like values are
B
= 0.1 % 0.1 % TAPE AND REEL (Lead (Pb)-free) 0.1 %
T0
= 100 min., 100 mult. required use total resistance.
C
= 0.25 % (e3) 0.1 %
T1
= 1000 min., 1000 mult. (3) When dual values are required
D
= 0.5 % 0.5 %
T3
= 300 min., 300 mult. list both values.
F
= 1 % 0.025 %
T5
= 500 min., 500 mult. 0000 = zero ohm jumper
Z
= 0.1 % (2) 0.01 %
TF
= full reel 4000 for R value
Q
= 0.05 % (2)
TS
= 100 min., 1 mult. UUUU = open connection in
N
= for jumpers only place of R value Example: (List R1 first in part number with dual values) 1002 = 10K (5K / 5K) 1003 = 100K (50K / 50K) 10011002 = 1K / 10K divider 0000UUUU = R1 = jumper, R2 = open UUUU0000 = R1 = open, R2 = jumper 00UUUU00 = jumper connection pin 1 to pin 2 0000 = R1 and R2 = jumpers 00001002 = R1 = jumper, R2 = 10K 50010000 = R1 = 5K, R2 = jumper
Historical Part Number Example: MPM1002BW (for reference purposes only) MPM 1002 B W
TOLERANCE AND SERIES RESISTANCE PACKAGING RATIO TOLERANCE
Notes
(1) For combinations of a resistor and a zero ohm jumper only the absolute tolerance applies to the resistor value (2) Tolerance available 1K and up equal values only (3) Preferred packaging code Revision: 03-Jan-2022
3
Document Number: 60001 For technical questions, contact: thinfilm@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
