Datasheet CPC1004N (Littelfuse) - 4
Manufacturer | Littelfuse |
Description | 100V, 300mA Single-Pole Normally Open Relay |
Pages / Page | 6 / 4 — CPC1004N. PERFORMANCE DATA*. Typical Load Current vs. Load Voltage. … |
File Format / Size | PDF / 195 Kb |
CPC1004N. PERFORMANCE DATA*. Typical Load Current vs. Load Voltage. Turn-On Time vs. LED Forward Current
INTEGRATED CIRCUITS DIVISION
CPC1004N PERFORMANCE DATA* Typical Load Current vs. Load Voltage Turn-On Time vs. LED Forward Current Turn-Off Time vs. LED Forward Current (I =5mA) (I =100mA) (I =100mA) F L L
300 2.0 0.7 1.8 200 0.6 1.6 1.4 0.5 100
(ms) (ms)
1.2 0.4 0 1.0 0.8 0.3 -100 0.6
urn-On Time urn-Off Time
0.2
Load Current (mA) T
0.4
T
-200 0.1 0.2 -300 0 0 -1.5 -1.0 -0.5 0 0.5 1.0 1.5 0 5 10 15 20 25 30 35 40 45 50 0 5 10 15 20 25 30 35 40 45 50
Load Voltage (V) LED Forward Current (mA) LED Forward Current (mA) Typical On-Resistance vs. Temperature Typical Turn-On Time vs. Temperature Typical Turn-Off Time vs. Temperature (I =300mA) (I =200mA) (I =300mA) L L L
12 5.0 1.0 4.5 0.9 10
4.0 0.8 : I = 5mA F
(ms)
3.5
(ms)
0.7 8 3.0 0.6 6 2.5 0.5 I = 10mA 2.0 0.4 F I =5mA 4 F 1.5 0.3
urn-On Time urn-Off Time On-Resistance ( T
I =10mA 1.0
T
0.2 F 2 0.5 0.1 I =10mA I =5mA F 0 0 0 F -40 -20 0 20 40 60 80 100 110 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100
Temperature (ºC) Temperature (ºC) Temperature (ºC) Typical Leakage vs. Temperature Typical Maximum Load Current Typical Blocking Voltage Measured Across Pins 3 & 4 vs. Temperature vs. Temperature (V =100V) L
500 122 0.016 450
121 0.014 400
P (V
0.012 120 350
e g A)
P 0.010 300 119
( olta e g
0.008 250 118 0.006 200
king V
I =5mA 117
Leaka
F I =10mA F 0.004
Load Current (mA)
150
Bloc
100 116 0.002 50 115 0 -40 -20 0 20 40 60 80 100 120 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100
Temperature (ºC) Temperature (ºC) Temperature (ºC) Energy Rating Curve
1.0 0.9 0.8 0.7 0.6 0.5 0.4 0.3
Load Current (A)
0.2 0.1 0 10μs 100μs 1ms 10ms 100ms 1s 10s 100s
Time
*Unless otherwise noted, data presented in these graphs is typical of device operation at 25ºC.
4 www.ixysic.com
R10
