Datasheet MAX4460, MAX4461, MAX4462 (Analog Devices) - 4
DescriptionSOT23, 3V/5V, Single-Supply, Rail-to-Rail Instrumentation Amplifiers
Pages / Page20 / 4 — SOT23, 3V/5V, Single-Supply, Rail-to-Rail Instrumentation Amplifiers
File Format / SizePDF / 436 Kb
SOT23, 3V/5V, Single-Supply, Rail-to-Rail Instrumentation Amplifiers ELECTRICAL CHARACTERISTICS—MAX4460/MAX4461 (continued)
(VDD = 5V, VCM = 0V, VDIFF = VIN+ - VIN- = 50mV to 100mV for G = 1, 20mV to 100mV for G = 10, 2mV to 48mV for G = 100, MAX4460 is configured for G = 10, RL = 200kΩ to GND,
TA = TMIN to TMAX
, unless otherwise noted.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
V Input Common-Mode Range V DD - CM Guaranteed by CMRR test -0.1 V 1.85 Input Common-Mode Rejection CMRR VCM = -0.1V to (VDD - 1.85V) 80 dB Ratio Power-Supply Rejection Ratio PSRR VDD = 2.85V to 5.25V 75 dB Input Bias Current IB (Note 2) 100 pA FB Input Current MAX4460 (Note 2) 100 pA 0.7 X VIH MAX4461 VDD SHDN Logic Levels V 0.3 X VIL MAX4461 VDD SHDN Input Current MAX4461, V SHDN = 0V or VDD (Note 2) 100 pA V RL = 200k DD - VOH Ω 4 VOH (Note 3) RL = 20kΩ 8 Output Voltage Swing mV RL = 200kΩ 0.25 VOL RL = 20kΩ 0.25 MAX4461UESA, TA = 0°C to +85°C 0.8 RL = 20kΩ TA = -40°C to +85°C 1.6
MAX4460/MAX4461/MAX4462
MAX4461TESA, TA = 0°C to +85°C 0.8 RL = 20kΩ TA = -40°C to +85°C 1.7 MAX4461HESA, TA = 0°C to +85°C 1.0 Gain Error RL = 20kΩ TA = -40°C to +85°C 2.0 % MAX4460ESA, TA = 0°C to +85°C 0.8 RL = 20kΩ TA = -40°C to +85°C 2.0 MAX446_EUT/ TA = 0°C to +85°C 1.8 MAX446_ETT, RL = 20kΩ TA = -40°C to +85°C 3.0 R TA = 0 L = 20kΩ °C to +85°C 0.20 Nonlinearity % (Note 1) TA = -40°C to +85°C 0.25
4 _______________________________________________________________________________________
