Datasheet IRFR9310, IRFU9310, SiHFR9310, SiHFU9310 (Vishay) - 7
ManufacturerVishay
DescriptionPower MOSFET
Pages / Page13 / 7 — IRFR9310, IRFU9310, SiHFR9310, SiHFU9310. Peak Diode Recovery dV/dt Test …
File Format / SizePDF / 266 Kb
IRFR9310, IRFU9310, SiHFR9310, SiHFU9310. Peak Diode Recovery dV/dt Test Circuit. D.U.T. Note. Fig. 10 - For P-Channel
IRFR9310, IRFU9310, SiHFR9310, SiHFU9310 Peak Diode Recovery dV/dt Test Circuit D.U.T Note Fig 10 - For P-Channel
Peak Diode Recovery dV/dt Test Circuit D.U.T.
+ Circuit layout considerations • Low stray inductance • Ground plane • Low leakage inductance current transformer - + - - + Rg • dV/dt controlled by R + g • I V SD controlled by duty factor “D” - DD • D.U.T. - device under test
Note
• Compliment N-Channel of D.U.T. for driver Driver gate drive Period P.W. D = P.W. Period V = - 10 Va GS D.U.T. l waveform SD Reverse recovery Body diode forward current current dI/dt D.U.T. V waveform DS Diode recovery dV/dt VDD Re-applied voltage Body diode forward drop Inductor current I Ripple ≤ 5 % SD
Note
a. V = - 5 V for logic level and - 3 V drive devices GS
Vishay Siliconix maintains worldwide manufacturing capability. Products may be manufactured at one of several qualified locations. Reliability data for Silicon Technology and Package Reliability represent a composite of all qualified locations. For related documents such as package/tape drawings, part marking, and reliability data, see www.vishay.com/ppg?91284. S21-0373-Rev. E, 19-Apr-2021
7
Document Number: 91284 For technical questions, contact: hvm@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
