Datasheet S102T02, S202T02 (Sharp) - 2
Manufacturer | Sharp |
Description | Zero Cross Type Low Profile SIP 4pin Triac Output SSR |
Pages / Page | 13 / 2 — S102T02 Series S202T02 Series. Internal Connection Diagram. Outline … |
File Format / Size | PDF / 245 Kb |
S102T02 Series S202T02 Series. Internal Connection Diagram. Outline Dimensions. S102T02. S202T02. S 1 0 2 T 0 2. S 2 0 2 T 0 2
1 Output (Triac T1) 2 Output (Triac T2) 3 Input (+) 4 Input (−) 1 2 3 4 Zero Crossing Circuit ■
Outline Dimensions
(Unit : mm)
S102T02 S202T02
23±0.2 23±0.2 0.2 0.2 7±0.2 ± ± 0.2 7±0.2 0.2 ± ± 1.8 4 1.8 4 Common to pin No.2 Common to pin No.2 3±0.2 3±0.2 Common to pin No.2 0.3 Common to pin No.2 0.3 ± 6.4±0.2 φ3.7±0.2 ± 6.4±0.2 φ3.7±0.2 4.5 UL mark 4.5 UL mark CSA mark CSA mark Epoxy resin Epoxy resin 0.2 0.2 ±
S 1 0 2 T 0 2
± 0.2
S 2 0 2 T 0 2
0.2 ± ± 2A125VAC 2A265VAC 11.5 Date code (2 digit) Date code (2 digit) 10 ∗ 10 11.5 (25.8) ~ + − ∗ (25.8) ~ + − 3-1.2±0.2 3-1.2±0.2 (3.5) 3-1.4±0.2 (3.5) 3-1.4±0.2 0.4±0.1 0.4±0.1 MIN. MIN. MIN. MIN. 4-0.8±0.2 MIN. MIN. 4-0.8±0.2 6.2 3.8 0.2 (0.8) 6.2 3.8 0.2 (1.8) (0.8) (1.8) 1.6±0.2 1 2 3 4 1.6±0.2 1 2 3 4 1.8±0.3 1.8±0.3 (3.8) (2.54) (3.8) (2.54) (5.08) (10.16) (5.08) (10.16) Product mass : approx. 3.5g Product mass : approx. 3.5g ∗ : Do not allow external connection. ( ) : Typical dimensions Sheet No.: D4-A01601EN 2
