Datasheet GBPC35005 - GBPC3510 (MCC)
ManufacturerMCC
Description35 Amp Glass Passivated Single Phase Bridge Rectifier 50 to 1000 Volts
Pages / Page3 / 1 — GBPC35005. Micro Commercial Components. THRU. GBPC3510. 35 Amp Glass. …
File Format / SizePDF / 432 Kb
GBPC35005. Micro Commercial Components. THRU. GBPC3510. 35 Amp Glass. Passivated Single. Phase Bridge Rectifier. 50 t. o 1000 Volts
Datasheet GBPC35005 - GBPC3510 MCC
M C C
GBPC35005
TM omponents
20736 Marilla Street Chatsworth
THRU
GBPC3510
Features • Halogen free available upon request by adding suffix "-HF"
35 Amp Glass
• Glass Passivated Chip Junction • Surge Rating Of 400 Amps
Passivated Single
• Mounting Hole For #10 Screw
• Any Mounting Position • With heat sink on top
50 t o 1000 Volts
• Epoxy meets UL 94 V-0 flammability rating • Moisture Sensitivity Level 1 • Lead Free Finish/RoHS Compliant(Note 1)("P" Suffix GBPC designates RoHS Compliant. See ordering information) A Maximum Ratings • Operating Temperature: -55°C to +150°C B • F Storage Temperature: -55°C to +150°C
AC
• UL Recongnized File # E165989 • Mounting Torgue: 8.0 in-lbs Maximum MCC Device Maximum Maximum Maximum Catalog Marking Recurrent RMS DC C D Number Peak Reverse Voltage Blocking Voltage Voltage GBPC35005 GBPC35005 50V 35V 50V GBPC3501 GBPC3501 100V 70V 100V GBPC3502 GBPC3502 200V 140V 200V E GBPC3504 GBPC3504 400V 280V 400V GBPC3506 GBPC3506 600V 420V 600V GBPC3508 GBPC3508 800V 560V 800V GBPC3510 GBPC3510 1000V 700V 1000V G H Electrical Characteristics @ 25°C Unless Otherwise Specified Average Forward IF(AV) 35.0A TC = 60°C Current J Peak Forward Surge IFSM 400A 8.3ms, half sine I Current Maximum Forward Voltage Drop Per VF 1.1V IFM = 17.5A per DIMENSIONS Element element; INCHES MM TJ = 25°C DIM MIN MAX MIN MAX NOTE A 1.114 1.134 28.30 28.80 Maximum DC B .634 .673 16.10 17.10 Reverse Current At IR 5µA T C .634 .673 16.10 17.10 J = 25°C D .543 .583 13.80 14.80 Rated DC Blocking 500uA TJ = 125°C E .693 .732 17.60 18.60 Voltage F 0.197 Nominal 5.00 Nominal ∅ G .030 .034 0.76 0.86 H .244 .256 6.20 6.50 I .291 .335 7.40 8.50 Notes: 1.High Temperature Solder Exemption Applied,see EU Directive Annex Notes 7. J .740 .850 18.80 21.60 www.mccsemi.com
1 of 3
Revision:
C
201
5/02/10
