Datasheet NCP1729 (ON Semiconductor) - 9
ManufacturerON Semiconductor
DescriptionSwitched Capacitor Voltage Inverter
Pages / Page22 / 9 — NCP1729. Figure 22. Negative Output Voltage Doubler. Curve. in (V). All …
File Format / SizePDF / 181 Kb
NCP1729. Figure 22. Negative Output Voltage Doubler. Curve. in (V). All Diodes. out (. Figure 23. Doubler Load Regulation,
NCP1729 Figure 22 Negative Output Voltage Doubler Curve in (V) All Diodes out ( Figure 23 Doubler Load Regulation,
NCP1729
1 6 OSC −Vout Vin 2 5 + + + + + 3 4 Capacitors = 3.3 F
A single device can be used to construct a negative voltage doubler. The output voltage is approximately equal to −2.0 Vin minus the forward voltage drop of each external diode. The performance characteristics for the above converter are shown below. Note that curves A and C show the circuit performance with economical 1N4148 diodes, while curves B and D are with lower loss MBRA120E Schottky diodes. 0 TA = 25°C −2.0 A AGE (V) T
Curve V R
−4.0
in (V) All Diodes out ( )
B A 3.0 1N4148 118 −6.0 C B 3.0 MBRA120E 107 , OUTPUT VOL out −8.0 C 5.0 1N4148 91 V D D 5.0 MBRA120E 85 −10.0 0 10 20 30 40 Iout, OUTPUT CURRENT (mA)
Figure 23. Doubler Load Regulation, Output Voltage vs. Output Current http://onsemi.com 9
