Datasheet RT2-418, RT2-433.92 (Telecontrolli) - 2
ManufacturerTelecontrolli
DescriptionRadio Transmitter Module with SAW Resonator
Pages / Page2 / 2 — Electrical Characteristics. Pin Description. Mechanical Dimensions. …
File Format / SizePDF / 17 Kb
Electrical Characteristics. Pin Description. Mechanical Dimensions. TYPICAL APPLICATION. telecontrolli. HEAD OFFICE & PLANT
Electrical Characteristics Pin Description Mechanical Dimensions TYPICAL APPLICATION telecontrolli HEAD OFFICE & PLANT
Ta = 25°C unless otherwise specified CHARACTERISTICS MIN TYP MAX UNIT V Supply Voltage CC 4 14 VDC I Supply Current S 3 mA F Working Frequency W 418/433.92 MHz Max Data Rate 4 KHz T Operating Temperature Range OP -40 +80 °C
17.78 mm 1 VCC Supply Voltage 2 GND Ground 3 IN Modulation Input 4 NC Not Connected 1 4 10.16 mm 5.08 mm 2 3 TOP VIEW
TYPICAL APPLICATION
Led + Vcc 1 16 12V M In 2 15 RT2 C 3 14 1 GND 4 4 13 5 5 12 0 6 11 2 7 10 6 8 9
Via Naz. delle Puglie 177 80026 Casoria (NA), Italy Tel: +39 081 7599033 Fax: +39 081 7596494
