Datasheet MAX4754, MAX4754A, MAX4755, MAX4756, MAX4756A (Maxim) - 2
ManufacturerMaxim
Description0.5Ω, Quad SPDT Switches in UCSP/QFN
Pages / Page15 / 2 — 0.5. , Quad SPDT Switches in UCSP/QFN. ABSOLUTE MAXIMUM RATINGS. Note 1:. …
File Format / SizePDF / 325 Kb
0.5. , Quad SPDT Switches in UCSP/QFN. ABSOLUTE MAXIMUM RATINGS. Note 1:. ELECTRICAL CHARACTERISTICS. PARAMETER. SYMBOL. CONDITIONS
0.5 , Quad SPDT Switches in UCSP/QFN ABSOLUTE MAXIMUM RATINGS Note 1: ELECTRICAL CHARACTERISTICS PARAMETER SYMBOL CONDITIONS
Ω
(All voltages referenced to GND.) Continuous Power Dissipation (TA = +70°C) V+, IN_, EN...-0.3V to +6V 16-Bump UCSP (derate 8.2mW/°C above +70°C) ..660mW COM_, NO_, NC_ (Note 1) ...-0.3V to (V+ + 0.3V) 16-Pin TQFN (derate 16.9mW/°C Continuous Current above +70°C)..1349mW NC1, NC2, COM1, COM2 (MAX4755)..±100mA ESD per Method 3015.7...±2kV NO_, NC_, COM_ (remaining terminal connections) ..±300mA Operating Temperature Range ...-40°C to +85°C Peak Current NC1, NC2, COM1, COM2 (MAX4755) Junction Temperature ..+150°C (Pulsed at 1ms, 10% duty cycle)..±200mA Storage Temperature Range ...-65°C to +150°C (Pulsed at 1ms, 50% duty cycle)..±150mA Bump Temperature (soldering) Peak Current NO_, NC_, Infrared (15s) ...+220°C COM__ (remaining terminal connections) Vapor Phase (60s) ...+215°C (Pulsed at 1ms, 10% duty cycle)..±500mA Lead Temperature (soldering, 10s) ...+300°C (Pulsed at 1ms, 50% duty cycle)..±400mA
Note 1:
Signals on NO_, NC_, COM_ exceeding V+ or GND are clamped by internal diodes. Limit forward-diode current to maximum current rating. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
(V+ = +2.7V to +5.25V, TA = -40°C to +85°C, unless otherwise noted. Typical values are at +3V and TA = +25°C.) (Notes 2, 3)
PARAMETER SYMBOL CONDITIONS TA MIN TYP MAX UNITS ANALOG SWITCH
VCOM_, TMIN to Analog Signal Range VNO_, 0 V+ V TMAX VNC_ MAX4755 (NO1, NO2, +25°C 0.5 0.85 N_3, N_4), MAX4754/ V+ = 2.7V, T MAX4754A/MAX4756/ MIN to 1.0 ICOM_= 10mA, MAX4756A TMAX On-Resistance RON VNC_ or VNO_ Ω = 0V or V+ +25°C 11.5 (Note 4) MAX4755 (NC1, NC2) TMIN to 8.0 12.5 TMAX +25°C 0.1 0.35 MAX4755 (NO1, NO2, V+ = 2.7V, N_3, N_4) MAX4754/ TMIN to 0.55 ICOM_ = 10mA, MAX4756 TMAX VNC_ or VNO_ Ω +25°C 0.2 0.4 = +1.5V On-Resistance Match (Notes 4, 5) MAX4755 (NC1, NC2) TMIN to 0.55 ΔRON Between Channels TMAX V+ = +2.7V +25°C 0.1 0.35 ICOM_ = 10mA, VNC_ or VNO_ = MAX4754A/MAX4756A Ω 0 or V+ TMIN to 0.55 (Notes 4, 5) TMAX V+ = 3V, MAX4755 +25°C 0.2 0.4 ICOM_ = 10mA, (NO1, NO2, N_3, N_4,
MAX4754/MAX4754A/MAX4755/MAX4756/MAX4756A
On-Resistance Flatness RFLAT(ON) VNO_ or VNC_ NO1, NO2), MAX4754/ TMIN to Ω 0.55 = 0V, 0.6V, or V+ MAX4754A/MAX4756/ TMAX (Note 6) MAX4756A
2 _______________________________________________________________________________________
