Datasheet DF15005S, DF1501S, DF1502S, DF1504S, DF1506S, DF1508S, DF1510S (Diodes) - 2
ManufacturerDiodes
Description1.5A Surface Mount Glass Passivated Bridge Rectifier
Pages / Page5 / 2 — DF15005S – DF1510S. Maximum Ratings and. Electrical Characteristics. …
File Format / SizePDF / 365 Kb
DF15005S – DF1510S. Maximum Ratings and. Electrical Characteristics. Characteristic. Symbol. Unit
DF15005S – DF1510S Maximum Ratings and Electrical Characteristics Characteristic Symbol Unit
(@TA = +25°C, unless otherwise specified.) Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
DF DF DF DF DF DF DF Characteristic Symbol Unit 15005S 1501S 1502S 1504S 1506S 1508S 1510S
Peak Repetitive Reverse Voltage VRRM Working Peak Reverse Voltage VRWM 50 100 200 400 600 800 1000 V DC Blocking Voltage VR RMS Reverse Voltage VR(RMS) 35 70 140 280 420 580 700 V Average Forward Rectified Current @ TA = +40°C IO 1.5 A Non-Repetitive Peak Forward Surge Current, 8.3ms I Single Half Sine-Wave Superimposed on Rated Load FSM 50 A Forward Voltage (Per Element) @ IF = 1.5A VFM 1.1 V Peak Reverse Current at Rated @ TA = +25°C 10 IRM µA DC Blocking Voltage (Per Element) @ TA = +125°C 500 I2t Rating for Fusing (t < 8.3ms) I2t 10.4 A2s Typical Total Capacitance per Element (Note 4) CT 25 pF Typical Thermal Resistance, Junction to Ambient (Note 5) RθJA 40 °C/W Operating and Storage Temperature Range TJ, TSTG -65 to +150 °C Notes: 4. Measured at 1.0MHz and applied reverse voltage of 4.0V DC. 5. Thermal resistance, junction to ambient, measured on PC board with 5.0mm2 (0.03mm thick) land areas. DF15005S – DF1510S 2 of 5 September 2022 Document number: DS17002 Rev. 13 - 2
www.diodes.com
© 2022 Copyright Diodes Incorporated. All Rights Reserved.
