Datasheet MAX3280E, MAX3281E, MAX3283E, MAX3284E (Analog Devices)
Description±15kV ESD-Protected 52Mbps, 3V to 5.5V, SOT23 RS-485/RS-422 True Fail-Safe Receivers
Pages / Page11 / 1 — here. MAX3280E/MAX3281E/. ±15kV ESD-Protected 52Mbps, 3V to 5.5V,. …
here. MAX3280E/MAX3281E/. ±15kV ESD-Protected 52Mbps, 3V to 5.5V,. MAX3283E/MAX3284E
Datasheet MAX3280E, MAX3281E, MAX3283E, MAX3284E Analog Devices
Click
here
for production status of specific part numbers.
MAX3280E/MAX3281E/ ±15kV ESD-Protected 52Mbps, 3V to 5.5V, MAX3283E/MAX3284E SOT23 RS-485/RS-422 True Fail-Safe Receivers General Description Benefits and Features
The MAX3280E/MAX3281E/MAX3283E/MAX3284E ● ESD Protection: are single receivers designed for RS-485 and RS-422 ±15kV Human Body Model communication. These devices guarantee data rates ±6kV IEC 1000-4-2, Contact Discharge up to 52Mbps, even with a 3V power supply. Excellent ±12kV IEC 1000-4-2, Air-Gap Discharge propagation delay (15ns max) and package-to-package ● Guaranteed 52Mbps Data Rate skew time (8ns max) make these devices ideal for multidrop clock distribution applications. ● Guaranteed 15ns Receiver Propagation Delay The MAX3280E/MAX3281E/MAX3283E/MAX3284E ● Guaranteed 2ns Receiver Skew have true fail-safe circuitry, which guarantees a logic-high ● Guaranteed 8ns Package-to-Package Skew Time receiver output when the receiver inputs are opened ● V or shorted. The receiver output will be a logic high if L Pin for Connection to FPGAs/ASICs all transmitters on a terminated bus are disabled (high ● Allow Up to 128 Transceivers on the Bus impedance). These devices feature 1/4-unit-load receiver (1/4-unit-load) input impedance, allowing up to 128 receivers on the ● Tiny SOT23 Package same bus. ● True Fail-Safe Receiver The MAX3280E is a single receiver available in a 5-pin ● -7V to +12V Common-Mode Range SOT23 package. The MAX3281E/MAX3283E single receivers have a receiver enable (EN or EN) function and ● 3V to 5.5V Power-Supply Range are offered in a 6-pin SOT23 package. The MAX3284E ● Enable (High and Low) Pins for Redundant Operation features a voltage logic pin that allows compatibility with ● Three-State Output Stage (MAX3281E/MAX3283E) low-voltage logic levels, as in digital FPGAs/ASICs. On the MAX3284E, the voltage threshold for a logic high ● Thermal Protection Against Output Short Circuit is user-defined by setting VL in the range from 1.65V to ● AEC-Q100 (MAX3280EAUK/V+ Only) VCC. The MAX3284E is also offered in a 6-pin SOT23
Ordering Information
package.
TOP Applications PART TEMP RANGE PIN- PACKAGE MARK
● Clock Distribution
MAX3280E
AUK+T -40°C to +125°C 5 SOT23 +ADVM ● Telecom Racks MAX3280EAUK/V+T -40°C to +125°C 5 SOT23 +AFME ● Base Stations ● Industrial Control
MAX3281E
AUT+T -40°C to +125°C 6 SOT23 +ABAT ● Local Area Networks
MAX3283E
AUT+T -40°C to +125°C 6 SOT23 +ABAU ● Automotive
MAX3284E
AUT+T -40°C to +125°C 6 SOT23 +ABAV
Pin Configurations appear at end of data sheet.
+Denotes a lead(Pb)-free/RoHS-compliant package. T = Tape and reel. /V denotes an automotive qualified part.
Selector Guide PART VL ENABLE DATA RATE PACKAGE
MAX3280E — — 52Mbps 5-Pin SOT23 MAX3281E — Active High 52Mbps 6-Pin SOT23 MAX3283E — Active Low 52Mbps 6-Pin SOT23 MAX3284E ✔ — 52Mbps (Note 1) 6-Pin SOT23
Note 1:
MAX3284E data rate is dependent on VL. 19-2320; Rev 7; 1/19
