TS7805 Electrical Characteristics (Vin=10V, Iout=500mA, 0oC≤Tj≤125oC, Cin=0.33uF, Cout=0.1uF; unless otherwise specified.) Parameter Symbol TestConditions MinTypMaxUnit Tj=25oC 4.80 5 5.20 Output voltage Vout 7.5V≤Vin≤20V, 10mA≤Iout≤1A, 4.75 5 5.25 V PD≤15W 7.5V≤Vin≤25V -- 3 100 Line Regulation REGline Tj=25oC 8V≤Vin≤12V -- 1 50 mV 10mA≤Iout≤1A -- 15 100 Load Regulation REGload Tj=25oC 250mA≤Iout≤750mA -- 5 50 Quiescent Current Iq Iout=0, Tj=25oC -- 4.2 8 7.5V≤Vin≤25V -- -- 1.3 mA Quiescent Current Change ∆Iq 10mA≤Iout≤1A -- -- 0.5 Output Noise Voltage Vn 10Hz≤f≤100KHz, Tj=25oC -- 40 -- uV Ripple Rejection Ratio RR f=120Hz, 8V≤Vin≤18V 62 78 -- dB Voltage Drop Vdrop Iout=1.0A, Tj=25oC -- 2 -- V Output Resistance Rout f=1KHz -- 17 -- mΩ Output Short Circuit Current Ios Tj=25oC -- 750 -- mA Peak Output Current Io peak Tj=25oC -- 2.2 -- A Temperature Coefficient of mV/ ∆Vout/ ∆Tj Iout=10mA, 0oC≤Tj≤125oC -- -0.6 -- Output Voltage oC TS7806 Electrical Characteristics (Vin=11V, Iout=500mA, 0oC≤Tj≤125oC, Cin=0.33uF, Cout=0.1uF; unless otherwise specified.) Parameter Symbol TestConditions MinTypMaxUnit Tj=25oC 5.75 6 6.25 Output Voltage Vout 8.5V≤Vin≤21V, 10mA≤Iout≤1A, 6.3 6 6.3 V PD≤15W 8.5V≤Vin≤25V -- 5 120 Line Regulation REGline Tj=25oC 9V≤Vin≤13V -- 1.5 60 mV 10mA≤Iout≤1A -- 14 120 Load Regulation REGload Tj=25oC 250mA≤Iout≤750mA -- 4 60 Quiescent Current Iq Iout=0, Tj=25oC -- 4.3 8 8.5V≤Vin≤25V -- -- 1.3 mA Quiescent Current Change ∆Iq 10mA≤Iout≤1A -- -- 0.5 Output Noise Voltage Vn 10Hz≤f≤100KHz, Tj=25oC -- 45 -- uV Ripple Rejection Ratio RR f=120Hz, 9V≤Vin≤19V 59 75 -- dB Voltage Drop Vdrop Iout=1.0A, Tj=25oC -- 2 -- V Output Resistance Rout f=1KHz -- 19 -- mΩ Output Short Circuit Current Ios Tj=25oC -- 550 -- mA Peak Output Current Io peak Tj=25oC -- 2.2 -- A Temperature Coefficient of mV/ ∆Vout/ ∆Tj Iout=10mA, 0oC≤Tj≤125oC -- -0.7 -- Output Voltage oC z Pulse testing techniques are used to maintain the junction temperature as close to the ambient temperature as possible, and thermal effects must be taken into account separately. z This specification applies only for DC power dissipation permitted by absolute maximum ratings.
