Datasheet TS7800 (Taiwan Semiconductor) - 3
ManufacturerTaiwan Semiconductor
Description3-Terminal Fixed Positive Voltage Regulator
Pages / Page9 / 3 — TS7808 Electrical Characteristics. Parameter Symbol Test. Conditions Min. …
File Format / SizePDF / 270 Kb
TS7808 Electrical Characteristics. Parameter Symbol Test. Conditions Min. Typ. Max. Unit. TS7809 Electrical Characteristics
TS7808 Electrical Characteristics Parameter Symbol Test Conditions Min Typ Max Unit TS7809 Electrical Characteristics
(Vin=14V, Iout=500mA, 0oC≤Tj≤125oC, Cin=0.33uF, Cout=0.1uF; unless otherwise specified.)
Tj=25oC 7.69 8 8.32 Output Voltage Vout 10.5V≤Vin≤23V, 10mA≤Iout≤1A, 7.61 8 8.40 V PD≤15W 10.5V≤Vin≤25V -- 6 160 Line Regulation REGline Tj=25oC 11V≤Vin≤17V -- 2 80 mV 10mA≤Iout≤1A -- 12 160 Load Regulation REGload Tj=25oC 250mA≤Iout≤750mA -- 4 80 Quiescent Current Iq Iout=0, Tj=25oC -- 4.3 8 10.5V≤Vin≤25V -- -- 1 mA Quiescent Current Change ∆Iq 10mA≤Iout≤1A -- -- 0.5 Output Noise Voltage Vn 10Hz≤f≤100KHz, Tj=25oC -- 52 -- uV Ripple Rejection Ratio RR f=120Hz, 11V≤Vin≤21V 56 72 -- dB Voltage Drop Vdrop Iout=1.0A, Tj=25oC -- 2 -- V Output Resistance Rout f=1KHz -- 16 -- mΩ Output Short Circuit Current Ios Tj=25oC -- 450 -- mA Peak Output Current Io peak Tj=25oC -- 2.2 -- A Temperature Coefficient of mV/ ∆Vout/ ∆Tj Iout=10mA, 0oC≤Tj≤125oC -- -0.8 -- Output Voltage oC
(Vin=15V, Iout=500mA, 0oC≤Tj≤125oC, Cin=0.33uF, Cout=0.1uF; unless otherwise specified.)
Tj=25oC 8.65 9 9.36 Output Voltage Vout 11.5V≤Vin≤23V, 10mA≤Iout≤1A, 8.57 9 9.45 V PD≤15W 11.5V≤Vin≤26V -- 6 180 Line Regulation REGline Tj=25oC 12V≤Vin≤17V -- 2 90 mV 10mA≤Iout≤1A -- 12 180 Load Regulation REGload Tj=25oC 250mA≤Iout≤750mA -- 4 90 Quiescent Current Iq Iout=0, Tj=25oC -- 4.3 8 11.5V≤Vin≤26V -- -- 1 mA Quiescent Current Change ∆Iq 10mA≤Iout≤1A -- -- 0.5 Output Noise Voltage Vn 10Hz≤f≤100KHz, Tj=25oC -- 52 -- uV Ripple Rejection Ratio RR f=120Hz, 12V≤Vin≤22V 55 72 -- dB Voltage Drop Vdrop Iout=1.0A, Tj=25oC -- 2 -- V Output Resistance Rout f=1KHz -- 16 -- mΩ Output Short Circuit Current Ios Tj=25oC -- 450 -- mA Peak Output Current Io peak Tj=25oC -- 2.2 -- A Temperature Coefficient of mV/ ∆Vout/ ∆Tj Iout=10mA, 0oC≤Tj≤125oC -- -1 -- Output Voltage oC z Pulse testing techniques are used to maintain the junction temperature as close to the ambient temperature as possible, and thermal effects must be taken into account separately. z This specification applies only for DC power dissipation permitted by absolute maximum ratings. TS7800 series 3-9 2003/12 rev. A
