Datasheet NTCLE100E3 (Vishay)
ManufacturerVishay
DescriptionNTC Thermistors, Radial Leaded, Standard Precision
Pages / Page17 / 1 — NTCLE100E3. NTC Thermistors, Radial Leaded, Standard Precision. FEATURES. …
File Format / SizePDF / 226 Kb
NTCLE100E3. NTC Thermistors, Radial Leaded, Standard Precision. FEATURES. APPLICATIONS. LINKS TO ADDITIONAL RESOURCES. D 3
Datasheet NTCLE100E3 Vishay
NTCLE100E3
NTCLE100E3
www.vishay.com Vishay BCcomponents
NTC Thermistors, Radial Leaded, Standard Precision FEATURES
• Accuracy over a wide temperature range • High stability over a long life Available • Excellent price/performance ratio • cULus recognized, file E148885 (category XGPU2/XGPU8) • Mounting: radial • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912
• Temperature measurement, compensation, sensing and
control in consumer and industrial applications
D 3 DESCRIPTION 3 D 3D Models Design Tools Models Related
These thermistors have a negative temperature coefficient.
Documents
The part consists of a NTC chip, soldered between two tin plated copper wires. It has a gray base coating with a blue
QUICK REFERENCE DATA
colored dot. The coating has no specified insulation
PARAMETER VALUE UNIT
properties. Resistance value at 25 °C 3.3 to 470K Ω Tolerance on R25-value ± 2; ± 3; ± 5 %
PACKAGING
B25/85-value 2880 to 4570 K The thermistors are packed in bulk or tape on reel; see part Tolerance on B25/85-value ± 0.5 to ± 3 % numbers and relevant packaging quantities. Operating temperature range: At zero power dissipation;
DESIGN-IN SUPPORT
-40 to +125 continuously °C For complete Curve Computation, visit: At zero power dissipation; www.vishay.com/thermistors/ntc-curve-list/ ≤ 150 for short periods Response time (in oil) ≈ 1.2 s
MARKING
Thermal time constant τ 15 s The thermistors are with a blue colored dot; see dimensions (for information only) drawing and “Electrical Data and Ordering Information”. 7 Dissipation factor δ 8.5 mW/K (for information only)
MOUNTING
(for R25-value ≤ 680 Ω)
Important mounting and handling instructions: see
Maximum power dissipation 500 mW
www.vishay.com/doc?29222
at 55 °C Climatic category By soldering in any position. 40 / 125 / 56 - (LCT / UCT / days) Not intended for potted applications. Weight ≈ 0.3 g
ELECTRICAL DATA AND ORDERING INFORMATION UL SAP MATERIAL AND ORDERING NUMBER (1) R 25 R 25-TOL. B25/85 B25/85-TOL. RECOG. NTCLE100E3..B0/T1/T2 (
Ω
) (± %) (K) (± %) NTCLE100E3..B0A/T1A/T2A RoHS-COMPLIANT RoHS-COMPLIANT WITH EXEMPTION (2)
3.3 5 2880 3 338*B0 338*B0A 4.7 5 2880 3 478*B0 478*B0A 6.8 5 2880 3 688*B0 688*B0A 10 5 2990 3 109*B0 109*B0A 15 5 3041 3 159*B0 159*B0A 22 5 3136 3 229*B0 229*B0A 33 5 3390 3 ✓ 339*B0 339*B0A 47 5 3390 3 ✓ 479*B0 479*B0A 68 5 3390 3 ✓ 689*B0 689*B0A 100 5 3560 1.5 ✓ 101*B0 101*B0A 150 5 3560 1.5 ✓ 151*B0 151*B0A 220 5 3560 1.5 ✓ 221*B0 221*B0A Revision: 29-Jan-2024
1
Document Number: 29049 For technical questions, contact: nlr@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
