Datasheet MM74C74 (Fairchild)
Manufacturer | Fairchild |
Description | Dual D-Type Flip-Flop |
Pages / Page | 7 / 1 — MM74C74 Dual D-T. MM74C74 Dual D-Type Flip-Flop. General Description. … |
File Format / Size | PDF / 87 Kb |
MM74C74 Dual D-T. MM74C74 Dual D-Type Flip-Flop. General Description. Features. pe Fl. ip-. lop. Applications. Ordering Code:
MM74C74 Dual D-T
October 1987 Revised May 2002
MM74C74 Dual D-Type Flip-Flop y General Description Features pe Fl
The MM74C74 dual D-type flip-flop is a monolithic comple- ■ Supply voltage range: 3V to 15V mentary MOS (CMOS) integrated circuit constructed with ■ Tenth power TTL compatible: Drive 2 LPT2L loads
ip-
N- and P-channel enhancement transistors. Each flip-flop has independent data, preset, clear and clock inputs and Q ■ High noise immunity: 0.45 VCC (typ.)
F
and Q outputs. The logic level present at the data input is ■ Low power: 50 nW (typ.)
lop
transferred to the output during the positive going transition ■ Medium speed operation: 10 MHz (typ.) with 10V of the clock pulse. Preset or clear is independent of the supply clock and accomplished by a low level at the preset or clear input.
Applications
• Automotive • Data terminals • Instrumentation • Medical electronics • Alarm system • Industrial electronics • Remote metering • Computers
Ordering Code: Order Number Package Number Package Description
MM74C74M M14A 14-Lead Small Outline Integrated Circuit (SOIC), JEDEC MS-012, 0.150" Narrow MM74C74N N14A 14-Lead Plastic Dual-In-Line Package (PDIP), JEDEC MS-001, 0.300" Wide Devices also available in Tape and Reel. Specify by appending the suffix letter “X” to the ordering code.
Connection Diagram Truth Table Preset Clear Qn Qn
0 0 0 0 0 1 1 0 1 0 0 1 1 1 Qn Qn (Note 1) (Note 1)
Note 1:
No change in output from previous state. Note: A logic “0” on clear sets Q to logic “0”. A logic “0” on preset sets Q to logic “1”.
Top View
© 2002 Fairchild Semiconductor Corporation DS005885 www.fairchildsemi.com
