Datasheet S102C (Vishay)
ManufacturerVishay
DescriptionHigh Precision Foil Resistor with TCR of ± 2.0 ppm/°C, Tolerance of ± 0.005 % and Load Life Stability of ± 0.005 %
Pages / Page6 / 1 — S Series. High Precision Foil Resistor with TCR of ± 2.0 ppm/°C,
File Format / SizePDF / 133 Kb
Datasheet S102C Vishay
S Series
Vishay Foil Resistors
High Precision Foil Resistor with TCR of ± 2.0 ppm/°C, Tolerance of ± 0.005 % and Load Life Stability of ± 0.005 % FEATURES
Temperature coefficient of resistance (TCR): - 55 °C to + 125 °C, 25 °C ref.
Pb-free − S102C series: ± 2 ppm/°C typical (see table 1) Available − S102K series: ± 1 ppm/°C typical (see table 1)
RoHS*
• Rated power: to 1 W at + 125 °C
COMPLIANT
• Tolerance: ± 0.005 % • Load life stability: to ± 0.005 % at 70 °C, 2000 h at rated
Any value at any tolerance available within resistance range
power • Resistance range: 0.5 Ω to 1 MΩ (higher or lower values of
INTRODUCTION
resistance are available) Bulk Metal® Foil (BMF) technology outperforms all other • Electrostatic discharge above 25 000 V • resistor technologies available today for applications that Non inductive, non capacitive design • require high precision and high stability. Rise time: 1 ns without ringing • Current noise: < - 40 dB This technology has been pioneered and developed by • Thermal EMF: 0.05 µV/°C typical VISHAY, and products based on this technology are the • Voltage coefficient: < 0.1 ppm/V most suitable for a wide range of applications. BMF • Low inductance: < 0.08 µH typical technology allows us to produce customer orientated • Non hot spot design products, designed to satisfy challenging and specific • Terminal finishes available: lead (Pb)-free technical requirements. tin/lead alloy • Matched sets are available per request Model S Series made from Vishay BMF offers low TCR, (TCR Tracking: to 0.5 ppm/°C) excellent load life stability, tight tolerance, fast response • For better TCR and PCR performances please review the time, low current noise, low thermal EMF and low voltage
Z201
datasheet coefficient, all in one resistor. The S Series is virtually insensitive to destabillizing factors.
The resistor element is a solid alloy that displays the • High precision amplifiers desirable bulk properties of its parent material, thus it is • Down-hole (high temperature) inherently stable and noise free. • High precision instrumentation • Medical and test equipment Vishay’s Bulk Metal® S Series resistors are the modern • Industrial generation of precision resistors. The standard design of • Audio (high end stereo equipment) these resistors provides a unique combination of • EB applications (electron beam scanning and recording characteristics found in no other single resistor. equipment, electron microscopes) Our Application Engineering Department is available to • Military, airborne advise and to make recommendations. For non-standard • Measurement instrumentation technical requirements and special applications, please contact us.
FIGURE 1 - FOIL RESISTOR TCR COMPARISON OF FOIL ALLOYS IN MILITARY RANGE TABLE 1 - RESISTANCE VERSUS TCR + 150
(- 55 °C to + 125 °C, + 25 °C Ref.)
+ 100 TYPICAL TCR AND 1 ppm/
C RESISTANCE + 50 RESISTOR MAX SPREAD
Δ
R VALUE (
Ω
) R 0 (ppm/°C) (ppm) - 50
S102(C) 80 to < 150K ± 2 ± 2.5
- 100
S102(K) 80 to < 100K ± 1 ± 2.5
2 ppm/
C - 150
S102(C) ± 2 ± 3.5 50 to < 80
- 200
S102(K) ± 1 ± 3.5
- 50 - 25 0 + 25 + 50 + 75 + 100 + 125 - 55
S102(C) ± 2 ± 4.5
Temperature (°C)
1 to < 50
C Alloy K Alloy
S102(K) ± 1 ± 4.5
2 ppm/
C 1 ppm/
C
* Pb containing terminations are not RoHS compliant, exemptions may apply Document Number: 63001 For any questions, contact: foil@vishay.com www.vishay.com Revision: 20-Nov-07 1 Document Outline Datasheet Disclaimer
