Datasheet TDA8360; TDA8361; TDA8362 (Philips) - 3
Manufacturer | Philips |
Description | Integrated PAL and PAL/NTSC TV processors |
Pages / Page | 39 / 3 — QUICK REFERENCE DATA. SYMBOL. PARAMETER. CONDITIONS. MIN. TYP. MAX. UNIT. … |
File Format / Size | PDF / 243 Kb |
QUICK REFERENCE DATA. SYMBOL. PARAMETER. CONDITIONS. MIN. TYP. MAX. UNIT. Input voltages. Output signals. Control voltages
Philips Semiconductors Objective specification Integrated PAL and PAL/NTSC TV TDA8360; TDA8361; TDA8362 processors
QUICK REFERENCE DATA SYMBOL PARAMETER CONDITIONS MIN. TYP. MAX. UNIT
VP supply voltage 7.2 8.0 8.8 V IP supply current − 80 − mA
Input voltages
V45,46(rms) video IF amplifier sensitivity (RMS value) − 70 100 µV V5(rms) sound IF amplifier sensitivity (RMS value) − 1 − mV V6(rms) external audio input (RMS value) TDA8361, TDA8362 − 350 − mV V15(p-p) external CVBS input (peak-to-peak value) TDA8361, TDA8362 − 1 − V V22,23,24(p−p) RGB inputs (peak-to-peak value) − 0.7 − V
Output signals
VO(p-p) demodulated CVBS output − 2.4 − V (peak-to-peak value) I47 tuner AGC control current 0 − 5 mA V44 AFC output voltage swing − 6 − V V50(rms) audio output voltage (RMS value) − 700 − mV V18,19,20(p-p) RGB output signal amplitudes − 4 − V (peak-to-peak value) I37 horizontal output current 10 − − mA I43 vertical output current 1 − − mA
Control voltages
Vcontrol control voltages for Volume, Contrast, 0 − 5 V Saturation, Brightness, Hue and Peaking March 1994 3
