Datasheet MAX4091, MAX4092, MAX4094 (Maxim)
ManufacturerMaxim
DescriptionSingle/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps
Pages / Page16 / 1 — Single/Dual/Quad, Micropower, Single-Supply,. Rail-to-Rail Op Amps. …
File Format / SizePDF / 527 Kb
Single/Dual/Quad, Micropower, Single-Supply,. Rail-to-Rail Op Amps. MAX4091/MAX4092/MAX4094. General Description. Features
Datasheet MAX4091, MAX4092, MAX4094 Maxim
19-2272; Rev 0; 1/02
Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps MAX4091/MAX4092/MAX4094 General Description Features
The single MAX4091, dual MAX4092, and quad ♦
Low-Voltage, Single-Supply Operation (2.7V to 6V)
MAX4094 operational amplifiers combine excellent DC accuracy with Rail-to-Rail® operation at the input and ♦
Beyond-the-Rails™ Inputs
output. Since the common-mode voltage extends from ♦
No Phase Reversal for Overdriven Inputs
VCC to VEE, the devices can operate from either a sin- gle supply (2.7V to 6V) or split supplies (±1.35V to ♦
30µV Offset Voltage
±3V). Each op amp requires less than 130µA of supply ♦
Rail-to-Rail Output Swing with 1k
Load
current. Even with this low current, the op amps are capable of driving a 1kΩ load, and the input-referred ♦
Unity-Gain Stable with 2000pF Load
voltage noise is only 12nV/√Hz. In addition, these op ♦
165µA (max) Quiescent Current Per Op Amp
amps can drive loads in excess of 2000pF. ♦
500kHz Gain-Bandwidth Product
The precision performance of the MAX4091/MAX4092/ MAX4094 combined with their wide input and output ♦
High Voltage Gain (115dB)
dynamic range, low-voltage, single-supply operation, ♦
High Common-Mode Rejection Ratio (90dB) and
and very low supply current, make them an ideal choice for battery-operated equipment, industrial, and
Power-Supply Rejection Ratio (100dB)
data acquisition and control applications. In addition, ♦
Temperature Range (-40°C to +125°C)
the MAX4091 is available in space-saving 5-pin SOT23, 8-pin µMAX, and 8-pin SO packages. The MAX4092 is available in 8-pin µMAX and SO packages, and the MAX4094 is available in 14-pin TSSOP and 14-pin SO
Ordering Information
packages.
PART TEMP RANGE PIN-PACKAGE ________________________Applications MAX4091
AUK-T -40°C to +125°C 5 SOT23-5 Portable Equipment MAX4091ASA -40°C to +125°C 8 SO Battery-Powered Instruments MAX4091AUA -40°C to +125°C 8 µMAX Data Acquisition and Control
MAX4092
ASA -40°C to +125°C 8 SO MAX4092AUA -40°C to +125°C 8 µMAX Low-Voltage Signal Conditioning
MAX4094
AUD -40°C to +125°C 14 TSSOP MAX4094ASD -40°C to +125°C 14 SO
Pin Configurations/Functional Diagrams
TOP VIEW OUT1 1 14 OUT4 IN1- 2 13 IN4- N.C. OUT 1 MAX4091 8 N.C. 1 5 VCC OUT1 1 8 V MAX4092 CC MAX4091 IN1+ 3 12 IN4+ IN- V IN1- 2 7 CC 2 7 OUT2 V V EE 2 CC 4 11 VEE IN+ MAX4094 3 6 OUT IN1+ 3 6 IN2- IN2+ 5 10 IN3+ VEE 4 5 N.C. IN+ 3 4 IN- VEE 4 5 IN2+ IN2- 6 9 IN3- µ
MAX/SO SOT23
µ OUT2
MAX/SO
7 8 OUT3
TSSOP/SO
Rail-to-Rail is a registered trademark of Nippon Motorola, Ltd. Beyond-the-Rails is a trademark of Maxim Integrated Products, Inc.
________________________________________________________________ Maxim Integrated Products 1 For pricing, delivery, and ordering information, please contact Maxim/Dallas Direct! at 1-888-629-4642, or visit Maxim’s website at www.maxim-ic.com.
