Datasheet MAX4091, MAX4092, MAX4094 (Maxim) - 5
ManufacturerMaxim
DescriptionSingle/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps
Pages / Page16 / 5 — Single/Dual/Quad, Micropower, Single-Supply,. Rail-to-Rail Op Amps. …
File Format / SizePDF / 527 Kb
Single/Dual/Quad, Micropower, Single-Supply,. Rail-to-Rail Op Amps. MAX4091/MAX4092/MAX4094
Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps MAX4091/MAX4092/MAX4094
Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps MAX4091/MAX4092/MAX4094 Typical Operating Characteristics (continued)
(VCC = 5V, VEE = 0, TA = +25°C, unless otherwise noted.)
SUPPLY CURRENT PER AMPLIFIER SUPPLY CURRENT PER AMPLIFIER LARGE-SIGNAL GAIN vs. TEMPERATURE vs. SUPPLY VOLTAGE vs. OUTPUT VOLTAGE
220 200 120 V R 200 OUT = VCM = VCC/2 L = 10kW 180 110 180 MAX4091 toc10 µA) MAX4091 toc11 µA) MAX4091 toc12 160 VCC = 5V 160 100 RL = 1MW 140 140 90 R 120 VCC = 2.7V L = 100kW 120 100 GAIN (dB) RL = 1kW 80 80 100 60 70 80 SUPPLY CURRENT PER AMP ( 40 SUPPLY CURRENT PER AMP ( VCC = 6V 60 60 20 RL TO VEE 0 40 50 -50 -25 0 25 50 75 100 125 1 2 3 4 5 6 0 100 200 300 400 500 600 TEMPERATURE (°C) SUPPLY VOLTAGE (V) VCC - VOUT (mV)
LARGE-SIGNAL GAIN LARGE-SIGNAL GAIN LARGE-SIGNAL GAIN vs. OUTPUT VOLTAGE vs. TEMPERATURE vs. OUTPUT VOLTAGE
120 120 120 RL = 1MW RL = 1kW, 0.5V < VOUT < (VCC - 0.5V) RL = 1MW 110 115 110 MAX4091 toc15 MAX4091 toc13 MAX4091 toc14 RL TO VCC 110 RL = 100kW 100 100 105 90 R 90 L = 100kW R R 100 L = 1kW L = 10kW GAIN (dB) GAIN (dB) 80 80 R R L = 1kW L = 10kW 95 VCC = 2.7V VCC = 6V 70 70 90 LARGE-SIGNAL GAIN (dB) RL TO VEE 60 VCC = 2.7V 60 85 VCC = 6V RL TO VEE RL TO VCC 50 80 50 0 100 200 300 400 500 600 -60 -40 -20 0 20 40 60 80 100 120 140 0 100 200 300 400 500 600 VCC - VOUT (mV) TEMPERATURE (°C) VOUT (mV)
LARGE-SIGNAL GAIN LARGE-SIGNAL GAIN MINIMUM OUTPUT VOLTAGE vs. OUTPUT VOLTAGE vs. TEMPERATURE vs. TEMPERATURE
120 120 220 RL = 100kW, 0.3V < VOUT < (VCC - 0.3V) 200 RL TO VCC R 115 110 L = 1MW R 180 MAX4091 toc16 R L TO VCC MAX4091 toc17 MAX4091 toc18 V L = 100kW CC = 6V, RL = 1kW 110 VCC = 6V 100 160 (nV) 105 140 90 OUT 120 V 100 CC = 2.7V, RL = 1kW GAIN (dB) 100 80 RL = 1kW 95 80 RL = 10kW R MINIMUM V 70 L TO VEE 90 60 LARGE-SIGNAL GAIN (dB) VCC = 6V, RL = 100kW VCC = 2.7V 40 60 VCC = 2.7V 85 20 R VCC = 2.7V, RL = 100kW L TO VCC 50 80 0 0 100 200 300 400 500 600 -60 -40 -20 0 20 40 60 80 100 120 140 -60 -40 -20 0 20 40 60 80 100 120 140 VOUT (mV) TEMPERATURE (°C) TEMPERATURE (°C)
_______________________________________________________________________________________ 5
