Datasheet MAX4091, MAX4092, MAX4094 (Maxim) - 6
Manufacturer | Maxim |
Description | Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps |
Pages / Page | 16 / 6 — Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps. … |
File Format / Size | PDF / 527 Kb |
Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps. Typical Operating Characteristics (continued)
Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps Typical Operating Characteristics (continued)
(VCC = 5V, VEE = 0, TA = +25°C, unless otherwise noted.)
MAXIMUM OUTPUT VOLTAGE OUTPUT IMPEDANCE VOLTAGE-NOISE DENSITY vs. TEMPERATURE vs. FREQUENCY vs. FREQUENCY
200 1000 100 V 180 RL TO VEE CM = VOUT = 2.5V ÖHz) MAX4091 toc19 160 MAX4091 toc21 V ) MAX40912 toc20 CC = 6V, RL = 1kW W 100 140 VCC = 2.7V, RL = 1kW ) (mV) 120 OUT 100 10 10 - V 80 CC(V 60 VCC = 6V, RL = 100kW OUTPUT IMPEDANCE ( 1 40 VCC = 2.7V, RL = 100kW INPUT REFERRED 20 VOLTAGE-NOISE DENSITY (nV/ 0 0.1 1 -60 -40 -20 0 20 40 60 80 100 120 140 0.01 0.1 1 10 100 1,000 10,000 0.01 0.1 1 10 TEMPERATURE (°C) FREQUENCY (kHz) FREQUENCY (kHz)
CURRENT-NOISE DENSITY TOTAL HARMONIC DISTORTION PLUS TOTAL HARMONIC DISTORTION PLUS NOISE vs. FREQUENCY NOISE vs. FREQUENCY vs. PEAK-TO-PEAK SIGNAL AMPLITUDE
5.0 0.1 0.1 A A 4.5 V = 1 V = 1 1kHz SINE √Hz) 2VP-P SIGNAL MAX4091 toc22 4.0 80kHz LOWPASS FILTER MAX4091 toc23 MAX4091 toc24 22kHz FILTER RL TO GND RL = 1kW 3.5 RL = 2kW
MAX4091/MAX4092/MAX4094
3.0 2.5 0.01 0.01 2.0 RL = 10kW TO GND THD + N (%) THD + N (%) 1.5 RL = 100kW 1.0 RL = 10kW CURRENT-NOISE DENSITY (pA/ INPUT REFERRED 0.5 NO LOAD 0 0.001 0.001 0.01 0.1 1 10 10 100 1000 10,000 4.0 4.1 4.2 4.3 4.4 4.5 4.6 4.7 4.8 4.9 5.0 FREQUENCY (kHz) FREQUENCY (Hz) PEAK-TO-PEAK SIGNAL AMPLITUDE (V)
SMALL-SIGNAL TRANSIENT RESPONSE SMALL-SIGNAL TRANSIENT RESPONSE LARGE-SIGNAL TRANSIENT RESPONSE
MAX4091 toc25 MAX4091 toc26 MAX4091 toc27 VCC = 5V, AV = 1, RL = 10kΩ VCC = 5V, AV = -1, RL = 10kΩ VCC = 5V, AV = 1, RL = 10kΩ VIN VIN VIN 50mV/div 50mV/div 2V/div VOUT VOUT VOUT 50mV/div 50mV/div 2V/div 2µs/div 2µs/div 20µs/div
6 _______________________________________________________________________________________
