Datasheet MAX4091, MAX4092, MAX4094 (Maxim) - 7
Manufacturer | Maxim |
Description | Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps |
Pages / Page | 16 / 7 — Single/Dual/Quad, Micropower, Single-Supply,. Rail-to-Rail Op Amps. … |
File Format / Size | PDF / 527 Kb |
Single/Dual/Quad, Micropower, Single-Supply,. Rail-to-Rail Op Amps. MAX4091/MAX4092/MAX4094
Single/Dual/Quad, Micropower, Single-Supply, Rail-to-Rail Op Amps MAX4091/MAX4092/MAX4094 Typical Operating Characteristics (continued)
(VCC = 5V, VEE = 0, TA = +25°C, unless otherwise noted.)
SINK CURRENT vs. SOURCE CURRENT vs. LARGE-SIGNAL TRANSIENT RESPONSE OUTPUT VOLTAGE SUPPLY VOLTAGE
MAX4091 toc28 0 30 V V DIFF = 100mV CC = 5V, AV = -1, RL = 10kΩ -2 VDIFF = 100mV MAX4091 toc29 -4 25 MAX4091 toc30 VIN 2V/div -6 20 VCC = 6V -8 -10 15 -12 VCC = 2.7V 10 V V OUTPUT CURRENT (mA) -14 CC = 2.7V OUT OUTPUT CURRENT (mA) 2V/div -16 VCC = 6V 5 -18 -20 0 20µs/div 0 0.5 1.0 1.5 2.0 2.5 3.0 1.0 2.0 3.0 4.0 5.0 6.0 OUTPUT VOLTAGE (V) SUPPLY VOLTAGE (V)
Pin Description PIN MAX4091 MAX4091 NAME FUNCTION MAX4092 MAX4094 SOT23 SO/µMAX
1 6 — — OUT Amplifier Output 2 4 4 11 VEE Negative Supply 3 3 — — IN+ Noninverting Input 4 2 — — IN- Inverting Input 5 7 8 4 VCC Positive Supply — 1, 5, 8 — — N.C. No Connection. Not internally connected. — — 1 1 OUT1 Amplifier 1 Output — — 2 2 IN1- Amplifier 1 Inverting Input — — 3 3 IN1+ Amplifier 1 Noninverting Input — — 5 5 IN2+ Amplifier 2 Noninverting Input — — 6 6 IN2- Amplifier 2 Inverting Input — — 7 7 OUT2 Amplifier 2 Output — — — 8 OUT3 Amplifier 3 Output — — — 9 IN3- Amplifier 3 Inverting Input — — — 10 IN3+ Amplifier 3 Noninverting Input — — — 12 IN4+ Amplifier 4 Noninverting Input — — — 13 IN4- Amplifier 4 Inverting Input — — — 14 OUT4 Amplifier 4 Output
_______________________________________________________________________________________ 7
