Datasheet V275LA4P (Littelfuse)
ManufacturerLittelfuse
DescriptionMetal-Oxide Varistors
Pages / Page13 / 1 — Metal-Oxide Varistors. RoHS. Description. Agency Approvals. Agency File. …
Metal-Oxide Varistors. RoHS. Description. Agency Approvals. Agency File. Agency. Agency Approval. Number. Features
Datasheet V275LA4P Littelfuse
(MOVs) Radial Lead Varistors > LA Varistor Series LA Varistor Series
RoHS Description
The LA Varistor Series of transient voltage surge suppressors are radial leaded varistors (MOVs) that are designed to be operated continuously across AC power lines. These UL recognized varistors require very little mounting space, and are offered in various standard lead form options. The LA Varistor Series are available in four model sizes: 7mm, 10mm, 14mm and 20mm; and have a V voltage range from 130V to 1000V, and an M(AC)RMS energy absorption capability up to 360J. Some LA Series model numbers are available with clamping voltage selections, designated by a model number suffix of
Agency Approvals
either A or B. The 'A' selection is the standard model;
Agency File
the 'B' selection provides a lower clamping voltage.
Agency Agency Approval Number
See LA Series Device Ratings and Specifications UL1449 E320116 Table for part number and brand information. CECC 42201-006 IEC 61051-1
Features
IEC 61051-2 116895 IEC 60950-1 (Annex Q) for 14mm and 20mm only • Lead–free, Halogen- • No derating up to CECC 42201-006 Free and RoHS 85ºC ambient IEC 61051-1 E1273/F compliant. IEC 61051-2 • Available in tape and IEC 60950-1 (Annex Q) for 14mm and 20mm only • Energy absorption reel or bulk pack capability (W ) TM up to 360J
Additional Information
• Wide operating voltage range V 130V to 1000V M(AC)RMS
Datasheet Resources Samples Absolute Maximum Ratings
• For ratings of individual members of a series, see Device Ratings and Specifications chart
Continuous LA Series Units Steady State Applied Voltage:
AC Voltage Range (V ) 130 to 1000 V M(AC)RMS DC Voltage Range (V ) 175 to 1200 V M(DC)
Transients:
Peak Pulse Current (I ) TM For 8/20µs Current Wave (See Figure 2) 1200 to 6500 A Single Pulse Energy Range For 10/1000µs Current Wave (W ) 11 to 360 J TM Operating Ambient Temperature Range (T ) -55 to +85 OC A Storage Temperature Range (T ) -55 to +125 OC STG Temperature Coefficient (aV) of Clamping Voltage (V ) at Specified Test Current <0.01 %/OC C Hi-Pot Encapsulation (COATING Isolation Voltage Capability) (Dielectric must withstand indicated DC voltage for one minute per MIL-STD 202, Method 301) 2500 V COATING Insulation Resistance 1000 MΩ
CAUTION:
Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. © 2019 Littelfuse, Inc. Specifications are subject to change without notice. Revised: 12/17/19
