Datasheet V275LA4P (Littelfuse) - 10
Manufacturer | Littelfuse |
Description | Metal-Oxide Varistors |
Pages / Page | 13 / 10 — Metal-Oxide Varistors. VARISTOR MODEL SIZE. 7mm. 10mm. 14mm. 20mm. … |
File Format / Size | PDF / 1.6 Mb |
Metal-Oxide Varistors. VARISTOR MODEL SIZE. 7mm. 10mm. 14mm. 20mm. VOLTAGE. SYMBOL. MODEL. MIN. MAX. Product Dimensions (mm)
(MOVs) Radial Lead Varistors > LA Varistor Series
VARISTOR MODEL SIZE 7mm 10mm 14mm 20mm VOLTAGE SYMBOL MODEL MIN MAX MIN MAX MIN MAX MIN MAX Product Dimensions (mm)
A V130LA- - 12 - 16 - 20 - 26.5 V320LA - (0.472) - (0.630) - (0.787) - (1.043) V385LA- - 13 - 17 - 20.5 - 28 *SEATING A V1000LA - (0.0512) - (0.689) - (0.807) - (1.102) PLANE TRIM øD All - 9 (0.354) - 12.5 - 17 - 23 - - (0.492) - (0.669) - (0.906) L TRIM e All 4 (0.157) 6 (0.236) 6.5 8.5 6.5 8.5 6.5 8.5 25.4(1.00) Min. for (0.256) (0.335) (0.256) (0.335) (0.256) (0.335) Bulk pack(LA) only (Note 2) (Note 2) e1 V130LA- 1.5 3.5 1.5 3.5 1.5 3.5 1.5 3.5 V320LA (0.059) (0.138) (0.059) (0.138) (0.059) (0.138) (0.059) (0.138)
CRIMPED AND TRIMMED LEAD
V385LA- 2.5 5.5 2.5 5.5 Crimped leads are standard on LA types supplied in tape and reel and are denoted by the model letter "T." 2.5 5.5 2.5 5.5 V1000LA (0.098) (0.217) Model letter "S" denotes straight leads and letter "U" denotes special under (0.098) -crimped leads. (0.217) (0.098) (0.217) (0.098) (0.217) *Seating plane interpretation per IEC-717 E V130LA- - 5.6 - 5.6 - 5.6 - 5.6 V320LA - (0.220) - (0.220) - (0.220) - (0.220)
V 7mm Size 10mm Size 14mm Size 20mm Size RMS
V385LA- - 7.3 - 7.3 - 7.3 - 7.3
Dimension Voltage Min. Max.
V510LA
Min.
Max.
(0.287) -
Min.
(0.287) -
Max.
(0.287)
Min.
- (0.287)
Max. Model mm (in) mm (in) mm (in) mm (in) mm (in) mm (in) mm (in) mm (in)
V130LA-V320LA - 12 (0.472) V550LA- - - 16 (0.630) 8.3 - -8.3 20 (0.787) - 8.3 -- 26.5 (1 8.3 .043)
A
V680LA - (0.327) - (0.327) - (0.327) - (0.327) V385LA-V1000LA - 13 (0.512) - 17 (0.689) - 20.5 (0.807) - 28 (1.102)
ØD
All - 9 (0.354) V1000LA - - 12.5 (0.492) - - - - 17 (0.669) - 10.8 -- 23 (0.906) 10.8 - - - - - (0.425) - (0.425)
e
All 4 (0.157) 6 (0.236) 6.5 (0.256) 8.5 (0.335) 6.5 (0.256) 8.5 (0.335) 6.5 (0.256)(Note 2) 8.5(Note 2) V130LA-V320LA 1.5 (0.059) øb 3.5 (0.138) All 1.5 (0.059) 0.585 3.5 (0.1 0.685 38)0.76 1.5 (0.059) 0.86 3.5 (0.1 0.76 38) 0.86 1.5 (0.059) 0.76 3.5 (0.1 0.86 38)
e1
V385LA-V1000LA 2.5 (0.098) 5.5 (0.217) (Note 3) 2.5 (0.098) (0.023) 5.5 (0.21 (0.027) 7) 2.5 (0.098) (0.030) (0.034) 5.5 (0.21 (0.030) 7) (0.034) 2.5 (0.098) (0.030) 5.5 (0.21 (0.034) 7) (Note 2) (Note 2) V130LA-V320LA - 5.6 (0.220) - 5.6 (0.220) - 5.6 (0.220) - 5.6 (0.220) V385LA-V510LA - NOTES: 7.3 (0.287) - 7.3 (0.287) - 7.3 (0.287) - 7.3 (0.287)
E
V550LA-V680LA -1. 8.3 (0.327) Dimensions in millimeters, - 8.3 (0.327) inches in parentheses. - 8.3 (0.327) - 8.3 (0.327) V1000LA -2. - - 10mm (9mm min, 11mm Max) ALSO AV - AILABLE; - 10.8 (0.425) See Additional Lead Style Options - 10.8 (0.425) All
Øb
3. 1000V parts supplied with lead wire of diameter 1.00 ± 0.05 (0.039 ± 0.002). (Note 3) 0.585 (0.023) 0.685 (0.027) 0.76 (0.030) 0.86 (0.034) 0.76 (0.030) 0.86 (0.034) 0.76 (0.030)(Note 2) 0.86 (0.034)(Note 2)
A
All - 15 (0.591) - 19.5 (0.768) - 22.5 (0.886(Note 4) - 29.0 (1.142)
TRIM L
All 2.41 (0.095) 4.69 (0.185) 2.41 (0.095) 4.69 (0.185) 2.41 (0.095) 4.69 (0.185) 2.41 (0.095) 4.69 (0.185)
TRIM Notes : 1.
Dimensions in millimeters, (inches) in parentheses.
2.
10mm (9mm Min. & 11mm Max.) ALSO AVAILABLE; see additional lead style options
3.
1000V parts supplied with lead wire of diameter 1.00 -/+ 0.05 (0.039 -/+ 0.002)
4.
'A' Max. for V1000LC80A (P) = 24.00 (0.945”) © 2019 Littelfuse, Inc. Specifications are subject to change without notice. Revised: 12/17/19
