Datasheet MAX9910, MAX9911, MAX9912, MAX9913 (Analog Devices) - 6
Description200kHz, 4µA, Rail-to-Rail I/O Op Amps with Shutdown
Pages / Page17 / 6 — 200kHz, 4µA, Rail-to-Rail I/O Op Amps with Shutdown. Typical Operating …
File Format / SizePDF / 515 Kb
200kHz, 4µA, Rail-to-Rail I/O Op Amps with Shutdown. Typical Operating Characteristics (continued). SLEW RATE
200kHz, 4µA, Rail-to-Rail I/O Op Amps with Shutdown Typical Operating Characteristics (continued) SLEW RATE
(VDD = 3V, VSS = VCM = 0V, RL to VDD / 2, TA = +25°C, unless otherwise noted.)
SLEW RATE OUTPUT-SWING HIGH OUTPUT-SWING LOW vs. SUPPLY VOLTAGE vs. TEMPERATURE vs. TEMPERATURE
0.6 1000 10000 VOL = VOUT - VSS 0.5 RL = 1kΩ RL TO VDD MAX9910 toc10 0.4 MAX9910 toc11 MAX9910 toc12 RL = 1kΩ 1000 0.3 µS) 100 RL = 5kΩ 0.2 0.1 100 0 RL = 5kΩ SLEW RATE (V/ 10 RL = 100kΩ -0.1 RL = 100kΩ 10 -0.2 OUTPUT VOLTAGE SWING (mV) OUTPUT VOLTAGE SWING (mV) RL TO VSS -0.3 VOH = VDD - VOUT -0.4 1 1
MAX9910–MAX9913
1.8 2.6 3.4 4.2 5.0 5.5 -40 -15 10 35 60 85 -40 -15 10 35 60 85 SUPPLY VOLTAGE (V) TEMPERATURE (°C) TEMPERATURE (°C)
OPEN-LOOP GAIN OPEN-LOOP GAIN GAIN AND PHASE vs. TEMPERATURE (RL TO VSS) vs. TEMPERATURE (RL TO VDD) vs. FREQUENCY (RL =
, CLOAD = 15pF)
MAX9910 toc15 140 140 80 180 RL = 100kΩ R A L = 100kΩ GAIN V = 1000V/V 120 120 60 135 MAX9910 toc13 MAX9910 toc14 40 90 100 100 RL = 5kΩ RL = 5kΩ 20 45 80 80 (dB) (dB) PHASE 0 0 R R A VOL L = 1kΩ 60 L = 1kΩ A VOL 60 GAIN (dB) -20 -45 PHASE (DEGREES) 40 40 -40 -90 20 20 -60 -135 0 0 -80 -180 -40 -15 10 35 60 85 -40 -15 10 35 60 85 1 10 100 1k 10k 100k 1M TEMPERATURE (°C) TEMPERATURE (°C) FREQUENCY (Hz)
GAIN AND PHASE CROSSTALK TOTAL HARMONIC DISTORTION vs. FREQUENCY (RL = 5k
, CLOAD = 100pF) vs. FREQUENCY PLUS NOISE vs. FREQUENCY
MAX9910 toc16 100 225 0 -5 AV = 1000V/V MAX9912/MAX9913 80 180 -15 GAIN -20 60 135 MAX9910 toc17 MAX9910 toc18 -25 40 90 -40 -35 20 45 PHASE -45 0 0 -60 GAIN (dB) -55 -20 -45 THD+N (dB) PHASE (DEGREES) CROSSTALK (dB) -80 -65 -40 -90 -75 -60 -135 VOUT = 2VP-P -100 -80 -180 -85 -100 -225 -120 -95 1 10 100 1k 10k 100k 1M 10 100 1k 10k 100k 10 100 1k 10k FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz)
6 _______________________________________________________________________________________
