Datasheet MAX9910, MAX9911, MAX9912, MAX9913 (Analog Devices) - 8
Description200kHz, 4µA, Rail-to-Rail I/O Op Amps with Shutdown
Pages / Page17 / 8 — 200kHz, 4µA, Rail-to-Rail I/O Op Amps with Shutdown. Typical Operating …
File Format / SizePDF / 515 Kb
200kHz, 4µA, Rail-to-Rail I/O Op Amps with Shutdown. Typical Operating Characteristics (continued). SMALL-SIGNAL GAIN
200kHz, 4µA, Rail-to-Rail I/O Op Amps with Shutdown Typical Operating Characteristics (continued) SMALL-SIGNAL GAIN
(VDD = 3V, VSS = VCM = 0V, RL to VDD / 2, TA = +25°C, unless otherwise noted.)
SMALL-SIGNAL GAIN LARGE-SIGNAL GAIN vs. FREQUENCY vs. FREQUENCY
10 4 A A V = +1V/V V = +1V/V 8 VOUT = 100mVP-P 3 VOUT = 2VP-P C C LOAD = 15pF MAX9910 toc27 LOAD = 15pF MAX9910 toc28 6 2 4 1 2 0 0 GAIN (dB) GAIN (dB) -2 -1 -4 -2 -6 -3 -8 -10 -4
MAX9910–MAX9913
1 10 100 1000 1 10 100 FREQUENCY (kHz) FREQUENCY (kHz)
PERCENT OVERSHOOT OUTPUT WAVEFORM WITH RISO vs. CAPACITIVE LOAD (CLOAD = 100pF, RISO = 6.2k
4.0 MAX9910 toc30 AV = 1V/V AV = 1V/V 3.5 RL = 1MΩ IN+ MAX9910 toc29 3.0 50mV/div 2.5 RL = 100kΩ 2.0 OVERSHOOT (%) 1.5 OUTPUT 50mV/div 1.0 0.5 RL = 10kΩ 0 0 20 40 60 80 100 20µs/div CLOAD (pF)
OUTPUT WAVEFORM WITHOUT RISO (CLOAD = 100pF)
MAX9910 toc31 AV = 1V/V IN+ 50mV/div OUTPUT 50mV/div 20µs/div
8 _______________________________________________________________________________________
