Data SheetASSR-1410, ASSR-1411, and ASSR-1420 General-Purpose, Form A, Solid StateRelay (Photo MOSFET) (60V/0.6A/1Ω)DescriptionFeatures The Broadcom® ASSR-14XX Series consists of an AlGaAs Compact solid-state bidirectional signal switch infrared light-emitting diode (LED) input stage that is Single- and dual-channel normally-of Single-Pole- optically coupled to a high-voltage output detector circuit. Single-Throw (SPST) relay The detector consists of a high-speed photovoltaic diode 60V output withstand voltage array and driver circuitry to switch on/of two discrete high- 0.6A or 1.2A current rating (See the schematics for voltage MOSFETs. The relay turns on (contact closes) with ASSR-1411 connections A and B.) a minimum input current of 3 mA through the input LED. The Low input current: CMOS compatibility relay turns of (contact opens) with an input voltage of 0.8V Low on-resistance: or less. – 0.2Ω typical for DC-only The single-channel configurations, ASSR-1410 and ASSR- – 0.7Ω typical for AC/DC 1411, are equivalent to 1 Form A Electromechanical Relays High-speed switching: (EMR), and the dual-channel configuration, ASSR-1420, is – 0.1 ms (TON), 0.02 ms (TOFF) typical equivalent to 2 Form A EMR. They are available in 4-pin SO, High transient immunity: >1 kV/μs 6-pin DIP, 8-pin DIP, and gull wing surface mount for DIP High input-to-output insulation voltage (safety and packages. Their electrical and switching characteristics are regulatory approvals) specified over the temperature range of –40°C to +85°C. – 3750 Vrms for 1 minute per UL1577 They are used for general-purpose switching of signals and – CSA component acceptance low-power AC/DC loads. ASSR-1411 enables AC/DC and DC-only output Applications connections. For DC-only connection, the output current, IO, Telecommunication switching increases to 1.2A and the on-resistance, R(ON), reduces to Data communications 0.5Ω. Industrial controls CAUTION! It is advised that normal static precautions be Medical taken in the handling and assembly of this Security component to prevent damage and degradation EMR/Reed Relay replacement that may be induced by ESD. The components featured in this data sheet are not to be used in military or aerospace applications or environments. The components are not AEC-Q100 qualified and are not recommended for automotive applications. Broadcom AV02-0241EN March 15, 2023 Document Outline Description Features Applications Functional Diagram Truth Table Ordering Information Schematics ASSR-1410 ASSR-1411 Connection A ASSR-1411 Connection B ASSR-1420 Package Outline Drawings ASSR-1410 4-Pin Small Outline Package ASSR-1411 6-Pin DIP Package ASSR-1411 6-Pin DIP Package with Gull Wing Surface Mount Option 300 ASSR-1420 8-Pin DIP Package ASSR-1420 8-Pin DIP Package with Gull Wing Surface Mount Option 300 Solder Reflow Profile Regulatory Information Insulation and Safety Related Specifications Absolute Maximum Ratings Recommended Operating Conditions Package Characteristics Electrical Specifications (DC) Switching Specifications (AC) Applications Information On-Resistance and Derating Curves Turn-On Time and Turn-Off Time Variation
