19-1224; Rev 3; 1/0 7 High-Output-Drive, Precision, Low-Power, Single-Supply, Rail-to-Rail I/O Op Amps with ShutdownMAX4165–MAX4169General DescriptionFeatures The MAX4165–MAX4169 family of operational amplifiers ♦ 80mA (min) Output Drive Capability combines excellent DC accuracy with high output current ♦ Rail-to-Rail Input Common-Mode Voltage Range drive, single-supply operation, and rail-to-rail inputs and ♦ Rail-to-Rail Output Voltage Swing outputs. These devices operate from a single +2.7V to +6.5V supply, or from dual ±1.35V to ±3.25V supplies. ♦ 1.2mA Supply Current per Amplifier They typically draw 1.2mA supply current, and are guar- ♦ +2.7V to +6.5V Single-Supply Operation anteed to deliver 80mA output current. ♦ 5MHz Gain-Bandwidth Product The MAX4166/MAX4168 have a shutdown mode that ♦ 250µV Offset Voltage reduces supply current to 38µA per amplifier and ♦ 1 120dB Voltage Gain (RL = 100k Ω ) places the outputs into a high-impedance state. The ♦ 88dB Power-Supply Rejection Ratio MAX4165–MAX4169’s precision performance com- bined with high output current, wide input/output ♦ No Phase Reversal for Overdriven Inputs dynamic range, single-supply operation, and low power ♦ Unity-Gain Stable for Capacitive Loads to 250pF consumption makes them ideal for portable audio ♦ Low-Power Shutdown Mode: applications and other low-voltage, battery-powered Reduces Supply Current to 38µA Places systems. The MAX4165 is available in the space-saving Outputs in High-Impedance State 5-pin SOT23 package and the MAX4166 is available in ♦ Available in 5-Pin SOT23 Package (MAX4165) or a tiny 2mm x 2mm x 0.8mm µDFN package. 2mm x 2mm x 0.8mm µDFN (MAX4166)Selector GuideOrdering InformationAMPS PERSHUTDOWNPARTPACKAGEMODEPIN-TOPPARTTEMP RANGE MAX4165 Single — PACKAGEMARK MAX4166 Single Yes MAX4165 EUK-T -40°C to +85°C 5 SOT23-5 AABY MAX4167 Dual — MAX4166 EPA -40°C to +85°C 8 Plastic DIP — MAX4168 Dual Yes MAX4166ESA -40°C to +85°C 8 SO — MAX4169 Quad — MAX4166EUA -40°C to +85°C 8 µMAX — MAX4166ELA+T -40°C to +85°C 8 µDFN-8 AAG Applications +Denotes lead-free package. Ordering Information continued on last page. Portable/Battery-Powered Audio Applications Portable Headphone Speaker Drivers Laptop/Notebook Computers Pin Configurations Sound Ports/Cards TOP VIEW Set-Top Boxes Cell Phones Hands-Free Car Phones (kits) OUT 1 5 VCC Signal Conditioning MAX4165 Digital-to-Analog Converter Buffers VEE 2 Transformer/Line Drivers Motor Drivers IN+ 3 4 IN- Typical Operating Circuit appears at end of data sheet.SOT23-5 Pin Configurations continued at end of data sheet. ________________________________________________________________ Maxim Integrated Products1For pricing, delivery, and ordering information, please contact Maxim/Dallas Direct! at 1-888-629-4642, or visit Maxim’s website at www.maxim-ic.com.
