Datasheet MAX4165 (Analog Devices) - 5
Description | High-Output-Drive, Precision, Low-Power, Single-Supply, Rail-to-Rail I/O Op Amps with Shutdown |
Pages / Page | 17 / 5 — High-Output-Drive, Precision, Low-Power, Single-. Supply, Rail-to-Rail … |
File Format / Size | PDF / 1.2 Mb |
High-Output-Drive, Precision, Low-Power, Single-. Supply, Rail-to-Rail I/O Op Amps with Shutdown. MAX4165–MAX4169
High-Output-Drive, Precision, Low-Power, Single- Supply, Rail-to-Rail I/O Op Amps with Shutdown MAX4165–MAX4169 __________________________________________Typical Operating Characteristics
(VCC = +5.0V, VEE = 0V, RL = 100kΩ, TA = +25°C, unless otherwise noted.)
GAIN AND PHASE vs. FREQUENCY POWER-SUPPLY REJECTION RATIO GAIN AND PHASE vs. FREQUENCY (CL = 250pF) vs. FREQUENCY
MAX4165-01 MAX4165-02 70 216 70 216 10 A AVCL = +1000V/V AVCL = +1 60 VCL = +1000V/V 180 60 180 C 0 L = 250pF MAX4165-03A 50 144 50 144 -10 40 108 40 108 -20 30 72 30 72 -30 20 36 20 36 -40 GAIN (dB) GAIN (dB) PSRR (dB) 10 0 10 0 -50 PHASE (DEGREES) PHASE (DEGREES) 0 -36 0 -36 -60 -10 -72 -10 -72 -70 -20 -108 -20 -108 -80 -30 -144 -30 -144 -90 100 1k 10k 100k 1M 10M 100 1k 10k 100k 1M 10M 100 1k 10k 100k 1M 10M 100M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz)
SUPPLY CURRENT PER AMPLIFIER SHUTDOWN SUPPLY CURRENT OUTPUT IMPEDANCE vs. FREQUENCY vs. TEMPERATURE PER AMPLIFIER vs. TEMPERATURE
1000 1.6 80 VCC = +6.5V VCC = +6.5V 1.4 70 MAX4165-04 MAX4165-05 MAX4165-03B ) Ω 100 1.2 60 µA) 1.0 VCC = +2.7V 50 10 0.8 40 0.6 30 VCC = +2.7V OUTPUT IMPEDANCE ( SUPPLY CURRENT (mA) SUPPLY CURRENT ( 1 0.4 20 0.2 10 0.1 0 0 1 10 100 1k 10k 100k 1M 10M -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 FREQUENCY (Hz) TEMPERATURE (°C) TEMPERATURE (°C)
INPUT BIAS CURRENT INPUT BIAS CURRENT INPUT OFFSET VOLTAGE vs. COMMON-MODE VOLTAGE vs. TEMPERATURE vs. TEMPERATURE
80 80 2.25 SOT23-5 1.75 60 PACKAGE MAX4165-06 60 V MAX4165-07 MAX4165-08 CC = +6.5V VCC = +2.7V 1.25 40 40 V 0.75 CC = +2.7V, VCM = VCC 20 20 VCC = +6.5V, VCM = VCC 0.25 0 0 -0.25 VOLTAGE (mV) VCC = +2.7V, VCM = VEE -0.75 INPUT BIAS CURRENT (nA) -20 INPUT BIAS CURRENT (nA) -20 VCC = +6.5V, VCM = VEE -1.25 SO PACKAGE -40 -40 -1.75 -60 -60 -2.25 0 1 2 3 4 5 6 7 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 COMMON-MODE VOLTAGE (V) TEMPERATURE (°C) TEMPERATURE (°C)
_______________________________________________________________________________________ 5
