Datasheet MAX4165 (Analog Devices) - 7
Description | High-Output-Drive, Precision, Low-Power, Single-Supply, Rail-to-Rail I/O Op Amps with Shutdown |
Pages / Page | 17 / 7 — High-Output-Drive, Precision, Low-Power, Single-. Supply, Rail-to-Rail … |
File Format / Size | PDF / 1.2 Mb |
High-Output-Drive, Precision, Low-Power, Single-. Supply, Rail-to-Rail I/O Op Amps with Shutdown. MAX4165–MAX4169
High-Output-Drive, Precision, Low-Power, Single- Supply, Rail-to-Rail I/O Op Amps with Shutdown MAX4165–MAX4169 ____________________________Typical Operating Characteristics (continued)
(VCC = +5.0V, VEE = 0V, RL = 100kΩ, TA = +25°C, unless otherwise noted.)
OUTPUT VOLTAGE HIGH TOTAL HARMONIC DISTORTION TOTAL HARMONIC DISTORTION AND NOISE vs. TEMPERATURE AND NOISE vs. FREQUENCY vs. PEAK-TO-PEAK OUTPUT VOLTAGE
300 0.05 1 RL to VEE VOUT = 2Vp-p 500kHz LOWPASS FILTER MAX4165-18 MAX4165-19 250 MAX4165-17 VCC = +6.5V, RL = 100Ω R 0.04 R L = 25Ω L = 10kΩ TO VCC / 2 (mV) 200 0.1 RL = 250Ω 0.03 VCC = +2.7V, RL = 100Ω 150 0.02 RL = 2kΩ THD + NOISE (%) THD + NOISE (%) 100 0.01 OUTPUT VOLTAGE HIGH 0.01 50 f = 10kHz VCC = +6.5V OR + 2.7V, RL = 100kΩ R R L = 100kΩ L to VCC / 2 0 0 0.001 -40 -20 0 20 40 60 80 100 10 100 1k 10k 100k 4.0 4.2 4.4 4.6 4.8 5.0 TEMPERATURE (°C) FREQUENCY (Hz) PEAK-TO-PEAK OUTPUT (V)
CHANNEL-TO-CHANNEL ISOLATION SMALL-SIGNAL TRANSIENT RESPONSE SMALL-SIGNAL TRANSIENT RESPONSE vs. FREQUENCY (NONINVERTING) (INVERTING)
MAX4165-20 MAX4165-21 130 AVCL = +1V/V AVCL = -1V/V 125 MAX4165-19a 120 IN 115 (50mV/div) IN 110 (50mV/div) 105 100 OUT 95 (50mV/div) OUT 90 (50mV/div) CHANNEL-TO-CHANNEL ISOLATION (dB) 85 80 1k 10k 100k 1M 10M TIME (500ns/div) TIME (500ns/div) FREQUENCY (Hz)
LARGE-SIGNAL TRANSIENT RESPONSE LARGE-SIGNAL TRANSIENT RESPONSE (NONINVERTING) (INVERTING)
MAX4165-22 MAX4165-23 AVCL = +1V/V AVCL = -1V/V IN (2V/div) IN (2V/div) OUT (2V/div) OUT (2V/div) TIME (5µs/div) TIME (5µs/div)
_______________________________________________________________________________________ 7
