Datasheet MAX442 (Analog Devices) - 5
Description140MHz, 2-Channel Video Multiplexer/Amplifier
Pages / Page9 / 5 — 140MHz, 2-Channel Video Multiplexer/Amplifier. …
File Format / SizePDF / 107 Kb
140MHz, 2-Channel Video Multiplexer/Amplifier. ____________________________Typical Operating Characteristics (continued)
140MHz, 2-Channel Video Multiplexer/Amplifier ____________________________Typical Operating Characteristics (continued)
(TA = +25°C, unless otherwise noted.)
VOLTAGE-NOISE DENSITY CROSSTALK OUTPUT VOLTAGE SWING vs. FREQUENCY vs. FREQUENCY vs. LOAD RESISTANCE
1000 0 5
MAX442
4 MAX442-04 MAX442-05 MAX442-06 √Hz) -20 3 2 100 -40 1 -60 0 -1 10 CROSSTALK (dB) -80 -2 OUTPUT VOLTAGE (V) -3 -100 VOLTAGE-NOISE DENSITY (nV/ -4 1 -120 -5 1 10 100 1k 10k 100k 1 10 100 1000 10 100 1k 10k FREQUENCY (Hz) FREQUENCY (MHz) LOAD RESISTANCE (Ω)
SUPPLY CURRENT INPUT OFFSET VOLTAGE INPUT BIAS CURRENT vs. TEMPERATURE vs. TEMPERATURE vs. TEMPERATURE
40 5 1.0 I V CC CM = 0V 30 4 0.9 MAX442-07 MAX442-08 MAX442-09 3 0.8 20 µA) 2 0.7 10 1 0.6 0 0 0.5 -1 0.4 -10 -2 0.3 SUPPLY CURRENT (mA) -20 I INPUT BIAS CURRENT ( EE INPUT OFFSET VOLTAGE (mV) -3 0.2 -30 -4 0.1 -40 -5 0 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C)
OPEN-LOOP VOLTAGE GAIN COMMON-MODE REJECTION RATIO DIFFERENTIAL INPUT OFFSET VOLTAGE vs. TEMPERATURE vs. TEMPERATURE vs. TEMPERATURE
80 80 3 70 MAX442-10 70 MAX442-11 MAX442-12 2 60 60 1 50 50 40 40 0 30 30 -1 20 20 OPEN-LOOP VOLTAGE GAIN (dB) -2 10 10 COMMON-MODE REJECTION RATIO (dB) 0 DIFFERENTIAL INPUT OFFSET VOLTAGE (mV) 0 -3 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C)
4 _______________________________________________________________________________________
Document Outline not-recomm-data-sheet-cover.pdf Not Recommended for New Designs
