Datasheet AV, SMV (Pico Electronics)
ManufacturerPico Electronics
DescriptionIsolated DC-DC Converters
Pages / Page7 / 1 — SERIES AV/SMV. SURFACE MOUNT and PLUG-IN. Hi Voltage - Up to 500 VDC …
File Format / SizePDF / 309 Kb
SERIES AV/SMV. SURFACE MOUNT and PLUG-IN. Hi Voltage - Up to 500 VDC Output. Hi Reliability. Ultra-Miniature - Low Profile
Datasheet AV, SMV Pico Electronics
SERIES AV/SMV SURFACE MOUNT and PLUG-IN Hi Voltage - Up to 500 VDC Output Hi Reliability Ultra-Miniature - Low Profile Isolated DC-DC Converters NEW DUAL OUTPUT MODULES ± 100 to ±250 VDC OUT
This series of unregulated high voltage DC-DC converters are produced in an ultra-miniature encapsulated package. 110 different models are available. These single and dual output isolated units will operate over the temperature range of -25º C to +70º C with no heat sink or electrical derating. For military applications an operating temperature range of -55º C to +85º C is available. An optional environmental screening package per MIL-STD-883 is also available.
FEATURES TYPICAL CHARACTERISTICS:
1.25 watt output at 70º ambient
Test conditions:
25º C ambient and input voltage at nominal value unless Ultra-miniature size 0.400" height, 4.0 grams weight, 0.1 cubic inches volume otherwise specified. 5 input voltage ranges 5, 12, 15, 24 and 28 VDC
LINE REGULATION:
OUTPUT IS DIRECTLY PROPORTIONAL TO 100 megohm @ 1000 VDC input/output isolation THE INPUT. MIL-STD 883 options available
Input voltage range:
±10% all models No heat sink or electrical derating required
Output voltage tolerance at full load-nom. Input:
±3% New dual outputs: ± Vout 100 to 250 VDC Please keep loaded to minimum of 10% at all times.
