Datasheet 440CMQ030 (Vishay)
ManufacturerVishay
DescriptionSchottky Rectifier
Pages / Page5 / 1 — 440CMQ030. Technical Data. Data Sheet N0982, Rev D. 440CMQ030 SCHOTTKY …
File Format / SizePDF / 313 Kb
440CMQ030. Technical Data. Data Sheet N0982, Rev D. 440CMQ030 SCHOTTKY RECTIFIER. Features. 150. TJ operation. Center tap module
Datasheet 440CMQ030 Vishay
440CMQ030 Technical Data Data Sheet N0982, Rev D 440CMQ030 SCHOTTKY RECTIFIER Features 150
TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability Baseplate: Nickel plated; Terminals: Nickel plated PRM4 (Isolated) This is a Pb − Free Device Al SMC parts are traceable to the wafer lot Additional testing can be offered upon request Circuit Diagram Applications High current switching power supply Plating power supply Free-Wheeling diodes Reverse battery protection Converters UPS System Welding Maximum Ratings: Characteristics Symbol Condition Max. Units
Peak Repetitive Reverse Voltage VRRM - Working Peak Reverse Voltage VRWM 30 V DC Blocking Voltage VR 50% duty cycle @T 220(Per Leg) Average Rectified Forward Current I C =95°C, F(AV) rectangular wave form A 440(Per Device) Peak One Cycle Non-Repetitive Surge Current (Per Leg) IFSM 8.3 ms, half Sine pulse 3600 A Non-Repetitive Avalanche Energy(Peg Leg) EAS TJ=25℃,IAS=44A,L=0.20mH 198 mJ Repetitive Avalanche Current(Peg Current decaying linearly to zero in 1 Leg) IAR μsec Frequency limited by TJ 44 A max.VA=1.5×VR typical China - Germany - Korea - Singapore - United States http://www.smc-diodes.com - sales@ smc-diodes.com Document Outline 440CMQ030 SCHOTTKY RECTIFIER
