Datasheet 440CMQ030 (Vishay) - 2
ManufacturerVishay
DescriptionSchottky Rectifier
Pages / Page5 / 2 — 440CMQ030. Technical Data. Data Sheet N0982, Rev D. Electrical …
File Format / SizePDF / 313 Kb
440CMQ030. Technical Data. Data Sheet N0982, Rev D. Electrical Characteristics:. Characteristics. Symbol. Condition. Typ. Max. Units
440CMQ030 Technical Data Data Sheet N0982, Rev D Electrical Characteristics: Characteristics Symbol Condition Typ Max Units
440CMQ030 Technical Data Data Sheet N0982, Rev D Electrical Characteristics: Characteristics Symbol Condition Typ. Max. Units
Forward Voltage Drop(Per Leg)* VF1 @ 220A, Pulse, TJ = 25 C 0.43 0.50 @ 440A, Pulse, TJ = 25 C - 0.60 V VF2 @ 220A, Pulse, TJ = 125 C 0.33 0.41 @ 440A, Pulse, TJ = 125 C - 0.52 V Reverse Current(Per Leg)* IR1 @VR = rated VR, TJ = 25 C 0.7 20 mA IR2 @VR = rated VR, TJ = 125 C 600 1120 mA Junction Capacitance(Per leg) C @VR = 5V, TC = 25 C T fSIG = 1MHz 11500 14800 pF Voltage Rate of Change dv/dt - - 10,000 V/s Insulation Voltage VRMS - - 1000 V * Pulse width < 300 µs, duty cycle < 2%
Thermal-Mechanical Specifications: Characteristics Symbol Condition Specification Units
Junction Temperature TJ - -55 to +150 C Storage Temperature Tstg - -55 to +150 C Typical Thermal Resistance Junction to Case(Per leg) RJC DC operation 0.40 C/W Typical Thermal Resistance Junction to Case(Per package) RJC DC operation 0.20 C/W Typical Thermal Resistance, case to Rcs Mounting surface, smooth Heat Sink and greased 0.10 C/W Mounting 24(min) Mounting Torque T Torque 35(max) M - Kg-cm Terminal 35(min) Torque 46(max) Approximate Weight wt - 79 g Case Style PRM4 Isolated China - Germany - Korea - Singapore - United States http://www.smc-diodes.com - sales@ smc-diodes.com Document Outline 440CMQ030 SCHOTTKY RECTIFIER
