Datasheet IKCM15F60GA (Infineon)
ManufacturerInfineon
DescriptionDual In-Line Intelligent Power Module 3Φ -bridge 600V / 15A
Pages / Page17 / 1 — link. to. page. 17. Control. Integrated. POwer. System. (CIPOS™). …
Revision02_05
link. to. page. 17. Control. Integrated. POwer. System. (CIPOS™). IKCM15F60GA. Datasheet. Datasheet. Please. read. the. Important. Notice. and. Warnings. at
Datasheet IKCM15F60GA Infineon, Revision: 02_05
link to page 17 Control Integrated POwer System (CIPOS™) IKCM15F60GA Datasheet Datasheet Please read the Important Notice and Warnings at the end of this document V 2.5 www.infineon.com page 1 of 17 2017-09-06 Document Outline Table of contents CIPOS™ Control Integrated POwer System Features Target Applications Description System Configuration Pin Configuration Internal Electrical Schematic Pin Assignment Pin Description HIN(U, V, W) and LIN(U, V, W) (Low side and high side control pins, Pin 7 - 12) VFO (Fault-output and NTC, Pin 14) ITRIP (Over current detection function, Pin 15) VDD, VSS (Low side control supply and reference, Pin 13, 16) VB(U, V, W) and VS(U, V, W) (High side supplies, Pin 1 - 6) NW, NV, NU (Low side emitter, Pin 17 - 19) W, V, U (High side emitter and low side collector, Pin 20 - 22) P (Positive bus input voltage, Pin 23) Absolute Maximum Ratings Module Section Inverter Section Control Section Recommended Operation Conditions Static Parameters Dynamic Parameters Bootstrap Parameters Thermistor Mechanical Characteristics and Ratings Circuit of a Typical Application Switching Times Definition Electrical characteristic Package Outline Revision history
